Paint Or Powdercoat Subframes?
10 replies to this topic
#1 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 06 November 2011 - 09:42 PM
As above....Ive stripped my subframes bare and now Im going to get them blasted. My question is whats best to get them coated with? Paint (Im thinking spray Hammerite) or powdercoated?
The car wont be getting used over winter etc so just a summer car. Ideally I wont be using it on too many wet roads either unless Im headed to a show.
From my research paints good as you can touch it up easily but powdercoat looks awesome but can get chipped and then flake off in massive sections in no time.
I dont want to be continually stripping the frames and getting them redone so, from your experience, what do you find to be the best?
#2 Tupers
Tupers
  • 4,176 posts
Posted 06 November 2011 - 10:00 PM
Personally I've never seen anything that's been powder coated suffer the chipping and flaking you describe and would happily have a set of frames coated.
That said the frames for my estate will probably get spayed in 2K paint as we we can do it in house with a shorter turn around time.
#3 Brams96
Brams96
  • 2,308 posts
Posted 06 November 2011 - 10:51 PM
Why not get it galvanised?
#4 corrado vr6
corrado vr6
  • 678 posts
Posted 06 November 2011 - 11:04 PM
Well id say powdercoat all the way, i have never seen it chipping and flaking like i have read also, and when you think could you get the cleaned up as well as shotblasting will and can you get the paint into all the nooks and crannies like powdercoat can, and persoanlly i have always found powdercoat to be much tougher than paint
and it looks good in red to
#5 l_jonez
l_jonez
  • 1,453 posts
Por15 would get my vote
#6 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 06 November 2011 - 11:36 PM
por or chassis black. don't bother with powder coating.
#7 sixtyeight
sixtyeight
  • 630 posts
  • Local Club: forums.minidriver.com.au
Posted 07 November 2011 - 05:49 AM
why not bother with powder coating?
any real life experiences?
I was going to go with POR15 but then decided to go with powdercoating - easier and cheaper (sand blaster people organise it all!)
#8 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 07 November 2011 - 07:26 AM
have seen powder coat chip, once it does it sucks water in like mad. it doesn't happen all of the time, but 90% of stuff i've seen that's been coated it's chipped and peeled.
i've had stuff done that's blistered before it's even been used!!
there are either some awful coaters or powders out there ;)
Edited by ANON, 07 November 2011 - 07:27 AM.
#9 Mini 360
Mini 360
  • 4,933 posts
Posted 09 November 2011 - 11:04 PM
Well the powdercoaters I would be taking it to do stuff for offshore installations in the North Sea. And they dabble in wheel coating and parts :lol: Might be worth a discussion with them as Im not sure.
#10 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 10 November 2011 - 01:08 AM
well if they're that good i'm sure they will guarantee their work in writing for at least 10 years then, i wouldn't hold my breath though if i were you ;)
#11 TA2DMAC
TA2DMAC
  • 755 posts
  • Local Club: Michigan MINI Motorin Club
Posted 10 November 2011 - 03:42 AM
Powdercoat is much more durable then regular paint, which is why most of a transmission pans and trans axels are powedercoated from the factory. However a good base coat and rubberguard will go a long way. I don't think you'll get a 10 yr guarantee for any paint job, if you do run with it, especially an undercoat.
