Turbo holes? T2 R5
beestje007
, Aug 27 2006 06:02 PM
3 replies to this topic
Posted 27 August 2006 - 06:02 PM
hello, i bought a r5 T2 turbo, and i did a rebuilt today, but i found a crack in the exhausthousing, do u think its gonna be a problem???, see pics, it comes directly from an R5 and the turbo was running fine. I also have 4 holes in the middle, so 2 for the oil? and the other holes??? And the actuator on the turbo has 2 holes, what do i have to connect with this? because normaly theres only one hole... thanks for all replies
Posted 27 August 2006 - 06:08 PM
Yes that Exhaust housing is knackered. Fit for the bin!
The T2 from the R5GTT is a water cooled item, so there should be the oil 'pressure' feed ( usualy on the top of the bearing housing), an oil drain ( usualy on the bottom of the housing) and coolant flow and return.
As for the actuator, i dont know.
You will probibly get a better response on www.turbominis.co.uk regarding the T2 turbo
Posted 27 August 2006 - 06:19 PM
fit for the bin? garbage?
can i still use the turbo? So an in and outlet for the water and for the oil.
Posted 27 August 2006 - 06:32 PM
common problem... they will work like that but its not ideal obviously!
aLex
aLex
