so it needed calabrating, and with a little help from an article by DKLawson it was easy to do.
What you need is a resistor or several to fix either between the wires to the gauge,
or across the terminals of the sender itself, and the value needs to be as close to 156.5 Ohms
(we manged to get 157 Ohms from some random resistors i had in my box)!!
Havent installed it yet so cant tell exactly how well it relates to the level,
but it works well on the sender itself.
Quater of a tank seems to be the last block solid then empty it starts to flash.
At empty the last bar flashes:
Half full or empty (im an empty kinda guy):
Full O' Fuel:
Student bums do have a use!!
