If it was a later model, then it would have been quite easy to slide the
matrix out.
But it'll be damned fiddly to strip your heater apart whilst it's still in the car and anyway with your heater unit, you're going to have to remove the heater inlet and outlet pipes anyway.
So listen very carefully as I shall say this only once (thankfully I have the information saved on another forum): -
To remove you need to undo the screw or screws that hold it to the parcel shelf. You'll find those just behind the heater control switch.
Pull the 2 air-vent hoses away from each side of the heater casing.
Then you'll need to slacken the nut that holds it tightly in place via the bracket at the rear left of the heater casing.
Now you can lift it off the bracket and lower the casing to the floor. Unclip the spade terminal from the heater control switch and unclip the bullet connector on the wire that sits above the casing with a small screwdriver.
You now might want to put something down on the carpet in case of any coolant leakage.
Put a bowl underneath the 2 main heater hoses and undo the 2 jubilee clips and pull the 2 hoses free. Then drain the coolant into the bowl. There shouldn't be much, but make sure you get it all out of the heater matrix.
You'll then need to pull the large air-intake trunk off the side and then you can take the heater casing in doors and strip it down. There's just loads of screws to remove on one side and couple on the other, then you can lift the panel off on one side.
Once that's off you can inspect the inner casing and give it a spring clean, removing any debris, dead flies etc. Also clean the matrix fins too and spray some water through it to flush it thoroughly.
Refitting is of course the reverse of removal, but I'd refit that large air-intake trunk before fitting the heater casing back in place as that trunk is difficult to fit otherwise.
Edited by taffy1967, 15 December 2008 - 08:22 PM.
