Rubbing Tire Front Driver Side
Posted 28 October 2009 - 10:03 AM
1994
The mini I bought the other day has 12" wheels on. Looks good and drives nice but there is big rubbing happening on the front driver side wheel inside arch.
Its only when turning left and reversing whilst on left lock (not always full lock).
All the googling I've done suggests that 12" would be fine.
I'm wondering if it could be my weight casuing the issue.. I'm 6'3 and 18stone.
What ya reckon?
Posted 28 October 2009 - 10:08 AM
Posted 28 October 2009 - 11:04 AM
good luck
jacob
Posted 28 October 2009 - 01:15 PM
Posted 29 October 2009 - 07:27 AM
The wheel is turned in.
Edited by FloydeIOM, 29 October 2009 - 07:28 AM.
Posted 29 October 2009 - 07:34 AM
that wheel looks a long way forwards
Posted 29 October 2009 - 08:23 AM
I'll investigate the tie bars.. cheers Bungle..
Posted 29 October 2009 - 08:49 AM
Paul.
Posted 29 October 2009 - 09:06 AM
Posted 29 October 2009 - 09:57 AM
are your tie bars bent ?
I agree with Bungle, the wheel is way to far forward. I got 13x7 on mine and they dont even come that close.
Posted 29 October 2009 - 10:27 AM
Posted 29 October 2009 - 12:49 PM
As said though it doesn't take 5 minutes to check your tie rods but im placing my bets on the width of the wheels.
Paul.
Edited by Pauly, 29 October 2009 - 12:50 PM.
Posted 03 February 2010 - 07:07 PM
It will rub more on the drivers side because the suspension cones settles down more on this side (because the drivers side has more weight than the passengers because of the driver, flywheel, brake/clutch cylinders) If you look at your car directly infront you will notice its lower on one side.
Paul.
I now have this problem after replacing my 4.5" Rover Minilites with 5" Ultralites - problem is only on the drivers side. So how do I sort the problem? I'm rolling with 3 Ultralites and 1 Minilite at the moment!!!
Possible solutions:
1. Washer on the end of the tie rod
2. Replace tie rod bushes
3. Check tie rod isn't bent
4. Check knuckle joint?
Any other ideas???
Posted 03 February 2010 - 07:47 PM
Any other ideas???
There was a rover "factory fit" washer, that went between the subframe and front panel, to effectively push the front panel away from the wheel... - honestly, it was a genuine part, with proper part number - had a couple on my 94 mayfair.
Ryan.
Posted 03 February 2010 - 08:24 PM
Any other ideas???
Ryan.
Hmmmm, so fit a spacer between the two (or one only on the right side) bolts on the front of the subframe? When I bought the Mini it didn't have any nuts or bolts there! This would mean that the tracking wouldn't be affected as well I guess!
