Small Pipe Coming Out Of Exhaust Downpipe?
Posted 02 February 2009 - 04:42 PM
Year: K reg
Description of problem: Had to take exhaust off recently due to it rusting through and falling off! I have a cat so when I came to the downpipe it had a small diameter pipe, approx 10mm, that ran to the side of the engine, above the clutch casing. As it was a nightmare to try and undo i eventually saw red and ripped it out. I have replaced it with a colourtune spark plug as this was the only thing i could find that would fit, the top of which now sits against the bulkhead and rattles (extremely irritating), I have trawled the usual websites looking for a replacement part but haven't managed to source one. Does anyone know of anywhere that does these?
OR
If i replace the exhaust system do I have to replace it with a system that has a cat in or can i just get rid of it?
Thanks in advance
Jez
Posted 02 February 2009 - 04:53 PM
Posted 02 February 2009 - 04:56 PM
my old exhaust manifold had one, when i went for a LCB i did away with it
if it's the same thing and doesn't go anywhere just find a bolt and plug it up
Posted 02 February 2009 - 05:14 PM
As for if you require a cat, technically if your car was built with a cat it should keep it. If your engine number is on the VOSA list for cars expected to pass the tougher emissions test then you will need to keep it. Not all carb Minis of that year are required to pass the tighter test, you'll have to check with an MOT station, it depends on what their flowchart says.
Posted 02 February 2009 - 05:16 PM
dave
Posted 02 February 2009 - 05:29 PM
or/ if they say u must keep the cat
keep the cat box. get an LCB for a cat car, then fit it with a cat replace ment pipe (a bit of pipe that goes where the cat would). then when it comes to MOT time, fit the cat box on and link it up. once its passed, whip it off and put the pipe back on.
My friend is planning to do this his car, not a mini, but same idea applies.
Chris
Posted 02 February 2009 - 05:41 PM
id play it safe, and do what dan says.
Chris
Sounds a bit of a ball ache to have to keep swapping between the two just for the MOT! I was looking at the sports cat from minispares so will scrub round that idea due to price! I think I will go with what Dan said (cheers Dan
Thank you guys for the advice!
Jez
Posted 02 February 2009 - 05:43 PM
Chris
Sounds a bit of a ball ache to have to keep swapping between the two just for the MOT! I was looking at the sports cat from minispares so will scrub round that idea due to price! I think I will go with what Dan said (cheers Dan... as always) to see if my car has to come under the stricter tests, if not it will be done away with!
Jez
Play it safe lol its a 92 carb car, it does not require a cat for the mot, so remove it and solve the problem, all you have to do is pass a normal exhaust test
dave
Posted 02 February 2009 - 06:00 PM
This is how I believe it works but I'm not an MOT tester.
I don't know if a sport cat is going to be any good in an open-loop catalyst system (that's what yours is by the way). Open-loop systems generally run at much looser tollerances than closed loop systems and the cat used has to be able to cope with a wider range for lambda and fuel.
Posted 02 February 2009 - 11:55 PM
But if it was originally an injection Mini and the owner switched over to a carb, then it would probably fail the emissions test as it would still have to be tested at the higher level.
However if the injection Mini got fitted with a complete replacement carb engine from an older Mini model, then the car must be tested on the age of the engine and not the car.
