Torque Settings (reformatted)
40 replies to this topic
#1 YIANO
YIANO
  • 210 posts
Posted 19 October 2008 - 01:00 PM
in case anybody cares heres a list i borrowed off a site
Fastener Torque (lbft) Torque (kgm)
Drive shaft coupling U bolts (rubber cross inner joints) 8 to 12 1.11 to 1.66
Drive shaft nut (front hub, drum brakes). Continue tightening until next split pin slot aligns. Do not slacken off until the next slot aligns! 60 8.3
Tie rod to front subframe 20 to 24 2.8 to 3.3
Tie rod to lower front suspension wishbone 17 to 20 2.8 to 3.3
Front suspension upper support arm pivot shaft nut 45 to 60 6.2 to 8.3
Front suspension lower wishbone pivot shaft nut 30 to 35 4.1 to 4.8
Wheel nuts 40 to 45 5.5 to 6.2
Steering column/rack pinion clamp bolt 8 to 10 1.11 to 1.38
Steering arm to swivel hub 30 to 35 4.1 to 4.8
Steering track-rod end to steering arm 20 to 24 2.8 to 3.3
Steering-wheel nut 32 to 37 4.5 to 5.1
Swivel hub ball joint socket 70 to 80 9.6 to 11.1
Swivel hub ball joint to suspension arms 35 to 40 4.8 to 5.5
Track rod end to steering rack locknut 35 to 40 4.8 to 5.5
Steering rack U-bolts to floor 10 to 12 1.4 to 1.7
Steering-column clip bracket to cloumn clip and parcel shelf 13 to 18 1.8 to 2.5
Rear suspension rear hub nut. Continue tightening until next split pin slot aligns. Do not slacken off until the next slot aligns! 60 8.3
Rear radius arm pivot shaft nut 45 to 60 6.2 to 8.3
Backplate to rear radius arm bolts 18 to 22 2.5 to 3.0
Suspension and Steering, Mini Cooper 997/998cc
Caliper retaining bolts 35 to 40 4.8 to 5.5
Steering Lever ball joint 25 to 30 3.4 to 4.1
Suspension and Steering, Mini Cooper S Mk1-3
Drive Shaft Nut. Continue tightening until next split pin slot aligns. Do not slacken off until the next slot aligns! 150 20.7
Electrical Components
Fastener Torque (lbin) Torque (kgm)
Alternator (11AC) Brush box fixing screws 10 0.115
Alternator (11AC) Diode heat sink fixings 25 0.288
Alternator (11AC) through-bolts 45 to 50 0.518 to 0.576
Alternator (16ACR) Shaft nut 25 to 30 3.5 to 4.2
Distributor Clamp Bolt (fixed nut type) 50 0.576
Distributor Clab Bolt (fixed bolt type) 30 0.345
Engine (848cc, 998cc)
Camshaft Nut 60 to 70 8.3 to 9.7
Con Rod Big-end Bolts 35 to 38 4.8 to 5.3
Crankshaft Pulley Nut 70 to 80 9.7 to 11.1
Cylinder Head Stud Nuts 40 5.5
Cylinder Side Cover 3 to 4 0.42 to 0.55
Clutch Spring Housing to Pressure Plate set screws 16 2.2
Driving Strap to Flywheel set screw 16 2.2
Flywheel Centre Bolt 110 to 115 15.2 to 15.9
Flywheel Housing bolts and stud nuts 18 2.5
Gudgeon Pin Clamp Screws 22 to 25 3.0 to 3.5
Heater Control to Cylinder Head 6 to 8 0.83 to 1.11
Main Bearing set screws 60 to 65 8.3 to 9.0
Manifold to Cylinder Head 12 to 16 1.7 to 2.2
Oil Filter Bown Centre Bolt 12 to 16 1.7 to 2.2
Oil Pump 6 to 9 0.83 to 1.25
Oil Pipe banjo 35 to 40 4.8 to 5.5
Oil Pressure Release Valve - dome nut 40 to 45 5.5 to 6.2
Rocker Cover 3 to 4 0.41 to 0.55
Rocker Shaft Bracket Nuts 22 to 25 3.0 to 3.5
Spark Plugs 18 2.5
Timing Cover and Front Plate 1/4in UNF bolts 4 to 6 0.55 to 0.83
Timing Cover and Front Plate 5/16in UNF bolts 10 to 14 1.4 to 1.9
Water Pump 14 to 18 1.9 to 2.5
Water Outlet Elbow 6 to 9 0.83 to 1.25
Thermal Transmitter 16 2.2
Engine (970cc, 1071cc, 1275cc)
Use this data in conjuction with the data for Engine (850, 998cc)
Cylinder Head nuts (11 stud head) 42 5.8
Cylinder Head bolt (11 stud head) 25 3.5
Con Rod Big-end nuts (assemble dry only) 40 5.5
Main Bearing set screws (early type) 67 9.3
Main Bearing nuts (later type) 57 7.9
Gearbox
Third Motion Shaft bearing retainer screws 13 1.8
First Motion Shaft nut 150 20.7
Third Motion Shaft nut 150 20.7
Transmission Case to Crankcase 6 0.8
Transmission drain plug 25 3.5
Transmission case studs - 3/8in dia. UNC 8 1.1
Transmission case studs - 5/16in dia. UNC 6 0.8
Transmission case stud nuts 3/8in UNF 25 3.4
Transmission case stud nuts 5/16in UNF 18 2.5
Bottom Cover set screws 1/4in dia. UNC (change-speed tower) 6 0.8
Final Drive
Driven Gear to Differential Cage 60 8.3
Driving Flange to Differential nut (tighten to next split pin hole) 70 9.6
Differential Housing End Cover bolts 18 2.5
#2 Purple Tom
Purple Tom
  • 4,921 posts
Posted 19 October 2008 - 01:08 PM
Useful - I know its a pain in the a*se but do you think you'd be able to edit them so they read a bit clearer? Its just a bit too much of a jumble of characters and numbers to be a quick reference guide.
Nice one on posting it up though! ;D
#3 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 20 October 2008 - 11:40 AM
I'll see what I can do.
Can we attach tables to posts? If not it may have to be an image of an excel spreadsheet...
D
#4 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 22 October 2008 - 12:53 PM
Like this?
Please feel free to use, it should print onto one page if you tell it to, a useful addendum to the Haynes?
#5 Purple Tom
Purple Tom
  • 4,921 posts
Posted 22 October 2008 - 04:19 PM
Spot on Dave, thanks very much for that :thumbsup:
#6 JIMSINN
JIMSINN
    Starting My Mini Up
  • 1 posts
Posted 03 February 2009 - 01:27 PM
just what ive been looking for
cheers
#7 scrimshaw
scrimshaw
    Starting My Mini Up
  • 4 posts
Posted 12 September 2009 - 08:21 PM
Hi,
I'm building up a Blitz 2, and using metro front hubs for the front end. I bought them from a guy off ebay a couple of years ago who said they are the same as mini hubs (I now know different from reading this forum). Given that the handling characteristics of the buggy will be quite different from a front-engined mini, I'm planning on using them anyway (suggestions on ride height and damper settings welcome from anyone in the know)
Anyway - my on-topic question is what torque setting should I use for the sealed ball joint units that go with metro hubs?
I'd like to avoid shelling out for a Haynes manual just for this data, and googling doesn't help out much.
Many thanks, Scrim.
Edited by scrimshaw, 12 September 2009 - 08:22 PM.
#8 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 16 September 2009 - 10:54 AM
Hi,
Many thanks, Scrim.
Send me a PM, I've a Haynes manual for Metro's at home, so I'll be able to look this up if I remember.
Dave
#9 scrimshaw
scrimshaw
    Starting My Mini Up
  • 4 posts
Posted 19 November 2009 - 06:42 PM
I tried to google the information you need but have no luck in finding the torque setting.I will still search for it and share it here if i found them.
Thanks - I tried googling extensively before posting and got nowhere!! I understand that they are the same as the mini, so that is what I used.
Edited by scrimshaw, 19 November 2009 - 06:49 PM.
#10 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 12 August 2011 - 08:57 PM
What torque should the rear subframe to bulkhead bolts be at, the 4 which go into the body of the mini.
THanks!
#11 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 15 August 2011 - 01:55 PM
Not on there, but I'm fairly sure Haynes tells you.
#12 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 30 October 2011 - 10:36 AM
Hi,
I tried sending a PM to the original poster but to no avail. Does anyone have the source file for this so I can add NM to the values. All my torque wrenches are in NM.
Charlie
#13 sayli
sayli
  • 35 posts
Posted 08 November 2011 - 05:03 AM
Useful - I know its a having difficulties in the a*se but do you think you'd be able to modify them so they go through a bit clearer? Its just a bit too much of a jumble of figure kinds and data to be a quick manual guide.
#14 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 26 January 2012 - 11:51 AM
I only updated the list that the OP put up.
If anyone wants to volunteer to tidy it further then please let me know...
D
#15 Jake Didsbury
Jake Didsbury
  • 294 posts
  • Local Club: Barnsley Mini Club
Posted 05 June 2012 - 01:00 PM
Does this cover the metro 1275 auto also, or is it just the same for all 1275s?
Mini Spares
