Newbie - Ignition Switch
pheunos
, Nov 18 2008 08:57 AM
9 replies to this topic
Posted 18 November 2008 - 08:57 AM
Hello all,
Having promised myself a mini since my mum sold her 850 when I was a kid, my girlfriend and I have just become the keepers of what I believe to be a 1970 Mk3 mini 1000 (although I stand to be corrected).
It isn't starting by the key so I've removed the steering column cover and was able to remove 2 small screws on the steering lock assembly, allowing me to slide the ignition switch out the back. The switch is totally melted so I need a new one but can't seem to find one anywhere. Can anyone point me in the right direction?
Thanks in advance!
Phil.
Thanks in advance!
Phil.
Posted 18 November 2008 - 09:09 AM
See if you can identify which one it is from here, they should also be able to supply
http://www.somerford...hts-1959-75.pdf
http://www.somerford-mini.co.uk
Also http://www.minispares.com would be another place to try
Posted 18 November 2008 - 09:13 AM
Is this it? If so it is usually supplied as a whole assembly. Quite exspensive though. Someone probably has an extra one you can buy. I know I do problem is I live in Denmark. You should probably try and find out why it is melted so you don't have to buy one more again.
Posted 18 November 2008 - 09:30 AM
Thanks guys, I've just checked with Somerford and although the switch is listed in their catalogue the part is no longer available. I'll check minispares now
Scotauto, that's the one, but I was hoping that as the switch is removable I'd be able to buy it separately. Not looking too hopeful!
Posted 18 November 2008 - 09:43 AM
No that one is for the early minis and fits on the dashboard by the light switch, yours will look like the picture previously put up
Posted 18 November 2008 - 09:44 AM
that looks like the ignition barrel mounted on the switch panel so I don't think it will fit
Posted 18 November 2008 - 09:51 AM
AAHH!!! I guess I'll have to bite the bullet and buy one of these Steering Lock & Switch unless anyone has any other ideas?
Posted 18 November 2008 - 10:01 AM
try posting in the wanted section you might get lucky
and I don't think minispares have them in stock
Posted 18 November 2008 - 10:06 AM
Good thinking! I'll do that now. I've also just found the number of a local mini specialist so I'll try them too.
Thanks for the help.
