What Compressor Do I Need For Paint Spraying
4 replies to this topic
#1 mini.cooper998
mini.cooper998
  • 685 posts
  • Local Club: looking
Posted 18 November 2008 - 11:51 AM
Morning all,
I have a quandry my dear wife want to learn to paint spray (she is very practical) so for christmas i want to buy her a compressor (ever the romantic) the thing is everyone you ask tells you something different so can someone confirm
what HP do i need what CFM do i need What pressure do i need and what litre tank is best.
remember this wont be used too much more a s a hobbyu than a buisness just as projects near completion so say twice a year for resprays also she is into welded art so she will probably spray some of that etc.
can anyone help
cheers andy
ps dont realy want to spend over £100
thanks
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 18 November 2008 - 12:53 PM
A big one, IMO nothing less than a 50 ltr tank, but the bigger the better...
I've only ever sprayed one mini and that was with a 50 ltr compressor, and it was only good for a panel at a time, roof you could only do half then half.
but, I don't do paint, 'cause I'm cr*p at it...
Edited by GuessWorks.co.uk, 18 November 2008 - 12:55 PM.
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 18 November 2008 - 01:14 PM
A lot also depends on the spray gun you use.
I've got this gun
http://www.machinema...ent-air-brushes
1 Litre quick release syphon cup
1.2mm external mix nozzle
Average air consumption 6.0 cfm
Ideally suited for use with air compressors rated 1.5hp or above
And this one
1.4mm external mix nozzle.
Average air consumption 7cfm
Ideally suited for use with air compressors rated 2hp or above
Actually tells you what minimum spec of compressor you want is.. luckily my compressor is 3hp and 150 litres
http://www.machinema...mpressors-elect
I would say minimum 2hp is what you want, and if you can 100 litre tank. Don't forget you will also need an inline water trap
#4 mini.cooper998
mini.cooper998
  • 685 posts
Posted 18 November 2008 - 04:06 PM
i spoke to a manufacturer the other day and they have said a 110l tank 3hp minimum but that sounds very excessive and costs excessive
Andy
#5 mini.cooper998
mini.cooper998
  • 685 posts
Posted 19 November 2008 - 12:38 PM
has anyone tried these HVLP turbine systems as it works out cheaper than a 110litre tank compressor and all parts and it gives 80% coverage instead of 40% so more economical on the paint.
Andy
