Subs Under The Seat
1 reply to this topic
#1 zeroasylum
zeroasylum
  • 378 posts
Posted 19 November 2008 - 09:43 AM
I was thinking of fitting some 6.5" subs under the seats normally where people put 6X9's. Will they fit there and what do people think of these that I found on the net.
http://www.m-99.co.u...subwoofers.html
Zeroasylum
#2 boister77
boister77
  • 29 posts
  • Local Club: MOALA, SCMM, M|U
Posted 20 November 2008 - 01:52 AM
Zeroasylum
most 6.5" subs will fit under the rear seating depending on their motor structure/magnet. based on the t/s parameters, you could do (4) in a sealed enclosure or (2) in a ported enclosure. since volume/air space is a premium, to achieve good results, i recommend you find a sub with the smallest motor structure possible. in my opinion, the 6.5" sub from tangband best suits this application. it uses a neo motor which is more powerful than the typical ferrite motor twice its size.
check out this links for reference:
my build:
http://www.vtecminis...ls.php?album=17
the tangband subs:
http://www.parts-exp...tnumber=264-832
as for the subs you posted. i can't say much as very little is mentioned in terms of specs. however, if i were to going based on appearance, i would pass. based on the motor, it has very little xmech.
Edited by boister77, 20 November 2008 - 01:52 AM.
