Engine Identification
Posted 19 November 2008 - 10:33 PM
There is a number cast into the head, next to the centre rocker arms. It reads 29A6. The block has a cast code into it: WFM 1024 F (the last F is big).
The thermostat mounting holes are square to the front of the head, indicating a metro engine. There are no tappet covers. The hole that usually leads from the head to the heater matrix in the cabin is professionally plugged.
Any ideas on what year this engine might be? Any more information about it?
Posted 19 November 2008 - 10:35 PM
Posted 19 November 2008 - 10:36 PM
Posted 19 November 2008 - 10:38 PM
just bought the engine
O right yer I see know, its late lol, I'm not sure then, sorry.
Posted 19 November 2008 - 10:56 PM
This will give you the identification number....
Eg;
12H907PH101
From that you can work out exactly what you have!
J
Posted 19 November 2008 - 11:17 PM
Is there not a number on a plate rivited to the top front part of the block where it sticks out under the head (on the right hand side)?
Eg;
12H907PH101
J
no, it's been taken off
Posted 20 November 2008 - 08:21 AM
I'm afraid you're down to measuring,
Posted 20 November 2008 - 01:45 PM
Posted 20 November 2008 - 01:49 PM
Posted 20 November 2008 - 02:58 PM
and no an MG metro 1275 is just a different specification ordinary 1275, blocks exactly the same.
To give you an idea of what it's origins are, you're going to have to take the head off... check the valve sizes, and work out the compression ratio..
If you have the original carb attached, then read the code off that, and check on www.burlen.co.uk what it was originally attached to.
Edited by GuessWorks.co.uk, 20 November 2008 - 02:59 PM.
Posted 20 November 2008 - 03:17 PM
Thanks again for your help.
Posted 20 November 2008 - 04:54 PM
Posted 20 November 2008 - 07:40 PM
