Cd Player Problem
9 replies to this topic
#1 wmkccwhite
wmkccwhite
  • 409 posts
Posted 19 November 2008 - 11:54 PM
I have a wooden dash that has a place for a cd player. I fitted it over the weekend but when i drive it seems to make the cd skip. I can be on the smoothest road but it still skips at time. It seems to skip at the mid engine revs range. Anyone had this problem? if so what did you do to fix it?
thanks
#2 mini_lad_1990
mini_lad_1990
  • 614 posts
  • Local Club: aint got one yet!!
Posted 20 November 2008 - 12:17 AM
i had this so i put some spounge underneath the headunit and it seems to have worked a treat lol
#3 wmkccwhite
wmkccwhite
  • 409 posts
Posted 20 November 2008 - 12:19 AM
I will give that a go and see what happens. thanks
#4 lorry
lorry
  • 249 posts
Posted 20 November 2008 - 10:53 AM
Have you got your cage secured properly?is this a new cd player? did you have it in somewhere before the new dash board?
#5 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 20 November 2008 - 02:01 PM
Maybe try some rubber mounts? If not, then a different CD player may work.
#6 mini_lad_1990
mini_lad_1990
  • 614 posts
Posted 20 November 2008 - 11:39 PM
any luck with the idea mate??
cheers
#7 wmkccwhite
wmkccwhite
  • 409 posts
Posted 21 November 2008 - 12:29 AM
Hello everyone.. The CD player was in another car i had and worked well then. It has been sitting around about 6 months though.. The cage is properly secured. Im not sure about the rubber mounts...they would need to be quite tall..
mini Lad.. him still looking for some good foam padding to try. Will let you know how it works out when i get some though.
Thanks for asking
#8 dave1324
dave1324
  • 184 posts
  • Local Club: minis 'n' oatcakes
Posted 21 November 2008 - 02:24 AM
have you made sure it is proberly earthed? try running a small wire from the cd player chassis to a metal bolt or screw that is close to it, i had the same problem and this fixed it also the speakers would crackle at mid rpm aswell
#9 wmkccwhite
wmkccwhite
  • 409 posts
Posted 25 November 2008 - 12:11 AM
Its not a ground problem its a CD skipping problem but i think i have it sorted now.
#10 Marky Tizz
Marky Tizz
  • 2,434 posts
  • Local Club: LSMOC
Posted 25 November 2008 - 07:09 AM
My stereo skips even on the radio... earth problem? Also my iPod unit seems to have stopped functioning :S kinda weird 'because it only seemed to stop working at the same time as the stereo started skipping... now if we plug the iPod unit in, it gets really really REALLY hot, but doesn't work.
The stereo was in my car a good 18 months before it started acting up.
