Help! Unidentified Spring
reggie
, Nov 20 2008 08:42 AM
4 replies to this topic
Posted 20 November 2008 - 08:42 AM
1985 Mini Mayfair 998cc, Manual
Hi all,
I need some help, yesturday, I removed the gearbox and Diff from my mini to inspect it and replace the various seals\gaskets\boots. When I finally manged to free it and get the gearbox and diff out, there was a spring lying on the floor. Where did it come from and where does it go? It's about 1 1/4".
It's been buggung the hell out of me and I don't want to put everything back together until I know where the spring goes, I will take a photo of it needed.
Any help will be greatly appreciated.
Hi all,
Posted 20 November 2008 - 08:59 AM
have you removed the diff cover side plates..... if so this might be the spring that hiolds the ball detent in place on the gear change detent
Just a thought tho.
Rob
Just a thought tho.
Rob
Posted 20 November 2008 - 10:40 AM
Just a thought tho.
Rob
Yep, I have removed the sides, I will check the gear change detent, if there is no spring then hopefully that's where its come from... Cheers, will let you know.
Posted 20 November 2008 - 11:25 AM
Just a thought tho.
Rob
Thanks DaveRob, you were right... It is the first time I have ever had a gearbox out so I'm still learning my way around
Posted 20 November 2008 - 12:31 PM
if the spring has fallen out.....make sure the ball bearing didnt fall out while you are their....lol
Rob
Rob
