Pulling To The Left!
Posted 20 November 2008 - 11:49 AM
also it pulls to the left when braking, i have recently put new pistons in the calipers and new Green stuff pads!
help im confused :S
thanks
dom
Posted 20 November 2008 - 11:52 AM
or it could be the drivers side caliper is seized totally - i had that and i could exit stage left very well if i braked hard!
Edited by Wilson1275, 20 November 2008 - 11:52 AM.
Posted 20 November 2008 - 01:22 PM
As above, it sounds like the off side brakes aren't comming on properly and the near side are sticking on.
Posted 20 November 2008 - 04:03 PM
Check tyres and pressure, odd tread wear
then both wheels spin freely
then grab wheel top and bottom and check for play
Posted 20 November 2008 - 06:11 PM
so i put it on a rolling road brake tester as per mot station, and sure enough brakes are working perfectly, i can only put it down to a steering geometry problem, i measured the track length and it is slightly shorter on the left (5mm)
it is worth pointing out that i use the 10" jap cooper s alloys/steel wheels on my mini which do have a big offset, so any geometry problem is exagerated by the lever effect the wheels have by sticking out so far
i took the tie rods off and checked them for straightness,and to see they were both adjusted to the same length, which they were found to be fine, so the difference in length could be the tie rod mount on the front subframe?
anyway i didnt have chance to look it it for about a week, and only today i realised it wasnt doing it anymore? i dunno either!
Posted 20 November 2008 - 06:28 PM
Posted 20 November 2008 - 10:13 PM
Agreed - tracking *doesnt* cause the car to pull - tis a mythWell it won't have been the tracking, however far out it won't cause a car to consistantly pull to one side.
um - not in my experience it doesnt...have your wheels ballanced!!! that can throw the car sidewards
pulling is usually down to the castor angle being mis-matched, usually a bent tie-rod, or bent mount on subframe, knackered rubbers too..
Posted 20 November 2008 - 10:16 PM
Might be worth while checking everything is still aligned correctly.
