I have a '82 998 mini who was fully restored six years ago. the car was almost original with a few simple modifications.
i fit a maniflow 1.75" side exit lcb twin Su Hs2 with ram pipes,a simple polish 12g202 double springs and a 45D aldon red,lumenition coil and silicone 8mm leads and a ngk B9EG
spark plugs,and it rev until 6200rpm.
now i'm start building a fast road 998 and i'm looking for "some more power".
the "spec" will be someting like this:
-Close ratio gearbox (3.44 or 3.76 FD not decide yet)
-S/C drop gears --------------- I've fond ones here in Portugal...lucky i guess
-A block with cut out's to fit a 12g940 33/29
-A+ flat top +0.40 press fit (Was 998 Std press fit pistons?
-A+ press fit conrod ligthened and polished (575g)
-A series crankshaft
-Lightened Vernier
-45D Aldon Red
-Weber DCOE 40
-Maniflow 1.75" side exit exhaust system
-Maniflow Lcb
-Lightened flywheel and pressure plate
-Orange Clutch Diaphragm
-Uprated clutch plate
-Kent cam 295 scatter patern
-Kent cam ligthened follower set
-Facet Fast road fuel pump Kit
-Facet fuel pressure regulator
now some pic's
Edited by 9FDXEH4, 20 January 2009 - 12:44 PM.
