All about AngelEye headlights
1 reply to this topic
#1 marksmini
marksmini
  • 49,445 posts
  • Name: Mark
Posted 09 March 2004 - 09:03 PM
Frequently asked Questions about Angel Eye Headlamps
When does the Halo come on?
When you turn the sidelights on
What do I get in the kit?
A replacement headlamp that replaces your headlamp, Two sidelight bulbs with coloured covers (not all versions e.g. 10w versions). Sidelight wiring loom, rubber boot for the back of the headlamp.
Are they any better than sealed beam headlamps?
Any new headlamp will be better than sealed beam headlamps.
I have fitted a halogen conversion are they any better?
They are better as the Angel Eye has a modern crystal reflector like modern cars?
But I have sealed beam headlamps will they fit?
Disconnect the connector on the back of your sealed beam lamp, fit a H4 bulb to the angel eye lamp and refit the connector, simple
How does the Halo work?
Two 5w wedge/capless bulbs are mounted in the lamp, these create the patented halo effect. The coloured covers fit over the 5w bulbs to change the colour of the light, so if a bulb fails you can go to your local bulb stockist and ask for a standard bulb instead of asking for a green 5w bulb.
How do they fit?
Remove outer chrome ring if fitted, remove old headlamp with inner chrome ring, remove inner chrome ring and fit to new lamp. Connect two wires from Halo to two wires for the sidelight in the headlamp bowl.
Are they legal?
They are not E approved, technically all lamps must be E approved. You can add a zero to the price if you wanted E approved lamps. Do you have rear clear lenses on your car if yes then they are ILLEGAL.
So they are not legal but can I still fit them?
The dipped beam on these lamps dips straight down so they can be fitted to Left or Right hand drive cars, the headlamp/halo light must be white. An MOT station may pass or fail the lamps. The police should be OK as none of them no the law regarding the E approval numbers.
Will they fit my 1986 C reg Mini Mayfair?
Yes and your mates 1980 Land Rover
Can I buy replacement parts?
Yes Halogen Bulbs, Sidelight bulbs, Headlamp.
Can you replace my Angel Eye headlamp as it cracked because I fitted 100w bulbs, free of charge?
No as the instructions say do not fit higher wattage bulbs and it has waring notice on the back of the lamp.
Posted ImagePosted ImagePosted ImagePosted ImagePosted ImagePosted Image
Replacement headlamps for minis (including Clubmans or any vehicle using 7" headlamps)
This lamp replaces the entire headlamp, Fitted with a side light ring of light creating the 'Halo' effect, this is created by two 5w capless sidelight bulbs as fitted to most modern cars. The 'Halo'/Ring of light colour can be changed from standard whiteish light to Blue, Red & Green with bulb covers included with each headlamp, the headlamp in the centre of the Ring of light has a crystal lens and takes a H4 bulb again as fitted to most modern cars. The dipped beam dips straight down so it can be fitted to LHD & RHD cars.
www.minitrailers.com
#2 mini7racer
mini7racer
  • 418 posts
Posted 10 March 2004 - 09:16 AM
you forgot to add that yo fit them you have to cut the side light of and then attach the new side lights to this. also dont forget to re align you lights. mark where the deep beam shine on a wall etc tehn fit the new lights and adjust so they shine in the same place.
Karl.
