84 Mayfair Project
255 replies to this topic
#1 joakwin
joakwin
  • 958 posts
Posted 07 April 2009 - 04:01 PM
here's my 84 mayfair project
i picked up the car for 500 pounds, drove it home
its got a 998/auto
with it being 500 pounds i knew their was gonna be alittle rust
so no big deal, so im trying to get the car back on the road for less then 1000pounds counting
the cost of the vehicle in the 1st place
im gonna do all the work myself so that should cut the price down
i have a lincoln 175 but its from the states and i can't use it here being the differents in power
not a big deal
so im looking on ebay for a cheap used welder because their is a few rusted thur area's that are
gonna need some cutting and fitting of new panels
so my plan is to fit patch panels because their is no need to replace a big panel if all it needs is a small
sqaure
i used to weld and fab metal for a living so no problems their with bending up some sheet metal to make it fit
and i wouldn't say im a pro but im not bad at body work
anyways here's some pictures of the car when i 1st got it home
Edited by joakwin, 07 April 2009 - 04:04 PM.
#2 joakwin
joakwin
  • 958 posts
Posted 07 April 2009 - 04:07 PM
so i pulled the carpet today because the heater martix is leaking
from the looks of it, it has been for a long time
#3 joakwin
joakwin
  • 958 posts
Posted 07 April 2009 - 04:12 PM
passager side,
im gonna take the metal all the way down to bare steel on this side and if it has any small pin holes i'll weld them up but if not then im gonna just prime it for now
but before i get all deep into the work i need to order/replace the heater martix
but i think im gonna block it off on the motor so i can get to working on the floor while the part comes in the post
Edited by joakwin, 07 April 2009 - 04:14 PM.
#4 joakwin
joakwin
  • 958 posts
Posted 07 April 2009 - 04:30 PM
the area around the lights had some rust on it, the paint was starting to rust so i sanded it down to bare metal and put alittle primer on it
drivers side fender, this was filled with bondo
sanded down the rust and painted it with a rust paint and then primer
i have the metal filler patch cut and fitted but just havn't welded it in yet
#5 joakwin
joakwin
  • 958 posts
Posted 07 April 2009 - 04:32 PM
the back driver's side window, i sanded down all the rust to bare metal and primed it up
and ive made the patch for that area
#6 joakwin
joakwin
  • 958 posts
Posted 07 April 2009 - 04:49 PM
here is the filler patch just sitting on the car, checking for fit
bent the metal by hand
im bidding on a welder on ebay in my local area, and it ends saturday,
so if i win it, i'll be welding the patches in this next weekend
#7 joakwin
joakwin
  • 958 posts
Posted 07 April 2009 - 04:54 PM
here's a back view of how the patch will fit
ones i cut out the metal under it, and weld it in, it will be flush and the plan is to not have to use
much if any bondo to make it smooth
#8 joakwin
joakwin
  • 958 posts
Posted 13 April 2009 - 08:20 PM
over the weekend i picked up a clarke 110en turbo welder off of ebay for cheap
it came with some .9mm flux wire so im just gonna try that out
as i have to wait unit pay day to get
some mild steel wire and some of the gas cylinders
so tonight i started to weld in the floor pan patch for the drivers side with the flux wire
and im just trying to get a feel for this machine
and so far, its nothing like my lincoln 175 amp, it feels alot
cheaper then the lincoln machine
but i'll be ok ones i get alittle more time welding with it
i'll add pictures later on this weekend coming up so i can
weld it and clean it up a bit
still looking for some diy bed liner to cover the floor with
#9 joakwin
joakwin
  • 958 posts
Posted 19 April 2009 - 11:23 AM
i got the gas set up on my welder this pass friday
and saturday
i started to build a cowl induction bonnet out of a stock mini bonnet
i plan to make some type of an adapter to move my air filter into the lifted part of the bonnet
Edited by joakwin, 19 April 2009 - 11:28 AM.
#10 scotty_09
scotty_09
  • 76 posts
Posted 19 April 2009 - 12:31 PM
thats good for 500 mate. looking good have you got a date you want it ready for
#11 joakwin
joakwin
  • 958 posts
Posted 19 April 2009 - 06:45 PM
its gonna be a driven project car for the most part
my goal is to be able to drive it to work by june
but i want to have the side body lines shaved by dec
and the new steel dash done by july/aug
the only thing left to do with electrical work is getting the brake lights to work
and i'll have the heater core repair work done by wednesday and fitted back into the car by saturday
and monday im going to price out new headlights since i hit them and they fall of the rack where i had them
so no more sealed beam lights, gonna upgrade to something better
also im gonna price out some wheel arches
i have about 80pounds left over on my budget for this pay period, so maybe i can get the arches used on the forum here
and i should be good after that
#12 joakwin
joakwin
  • 958 posts
Posted 03 May 2009 - 05:57 PM
i started to shave the body lines of the fenders to body in the cowl area
and the body lines under the head lights
next of the list to shave is the body seam down the sides
but i just ran out of gas for my welder so i need to go and buy another
bottle
#13 joakwin
joakwin
  • 958 posts
Posted 03 May 2009 - 06:02 PM
the drivers floor board patch welded in
Edited by joakwin, 03 May 2009 - 06:05 PM.
#14 joakwin
joakwin
  • 958 posts
Posted 03 May 2009 - 06:07 PM
alittle paint put down on the floor, after i clipped off the whatever that stock stuff was on the floor
i didn't do the best job gettingthe stock stuff off, and it shows thur the paint but oh well, im gonna cover it up
with some fat mat anyways so its all good
Edited by joakwin, 03 May 2009 - 06:09 PM.
#15 joakwin
joakwin
  • 958 posts
Posted 03 May 2009 - 06:21 PM
my bicycle next to the car
i got new inner cv boots on order, gaz adjustable lowered shocks, hd tie rods with poly and rubber bushings
and i got in the post the other day, new heater matrix, hi-lo's and wipac h4 conversion headlights
and come monday im gonna see how much new front wheel bearings are because i need those also
and i got my new amp in the mail also
ma audio hk802sx, 4400watts rms@1ohm
http://www.maaudio.c...htm?id=9&cid=12
i have a pair of tc sounds tc-9 magnets that are gonna be built into a pair of 12's
pair of custom built 12's for 4400watts of bass
i got some of the metal to build my custom battery rack
so i think with the weight of the stereo coming, im gonna go with the red springs on the coil conversion
that i still need to save up for
but the car is coming along and i hope to have it on the road soon
Edited by joakwin, 03 May 2009 - 06:22 PM.
