Cylinder Head Leaking Water....
Posted 12 April 2009 - 08:24 PM
Thanks for ur feed-back...
Posted 12 April 2009 - 08:27 PM
Have a look in the morning when it's light and make sure you're absolutely certain where the water's coming from. It's likely to be either the water pump or bypass hose...
Tom
Posted 13 April 2009 - 09:20 AM
Are you sure it's coming from the head?? It may well be the water pump or bypass hose...
Tom
I put a new bypass hose, which doesnt leak, and theres a new gasket on the thermo, and there are no leaks from either..
...the leak is defo coming from were the head meets the block, you can see small bubbles forming and going...
I think that the cylinder head is warped...
Edited by fpsasm, 13 April 2009 - 09:21 AM.
Posted 13 April 2009 - 09:26 AM
Posted 13 April 2009 - 09:28 AM
Posted 13 April 2009 - 09:30 AM
Posted 13 April 2009 - 09:58 AM
Posted 13 April 2009 - 10:01 AM
...id always check a cylinder head with a straight edge to ensure it has no gaps
but what do you check your staight edge with ??
THE ONLY WAY TO CHECK A HEAD IS WARPED IS TO GET IT SKIMMED
Posted 13 April 2009 - 10:07 AM
thats what i was taught
Posted 13 April 2009 - 10:57 AM
Just a suggestion..
Posted 13 April 2009 - 12:43 PM
to be honest i thought it was only 70 year olds who still said to check a head with a straight edge
Posted 13 April 2009 - 02:45 PM
put it this way, i've seen heads that people have checked with a straight edge (usually a metal rule) claimed they are true and needed loads of skimming.
I have a few years before I'm 70 years old, and, I own a precision straight edge which cost more than you probably earn in a week!
Posted 13 April 2009 - 11:16 PM
62 years till i reach that ripe age.
