Electric Windows A Guide From Sweden
4 replies to this topic
#1 kez_19
kez_19
  • 946 posts
Posted 07 May 2009 - 05:20 AM
i have come across this guide on a mini forum here in Sweden and i thought i would translate it and post it here for you all to look at hope it helps
This is what the mechanism looks like removed from the donor SAAB 9000
Remove the motor from the rest of the mechanism and you will see this plastic bit that fits perfectly over the mini winder handle fitment.
then take the plastic bit and drill 3 3mm holes don't forget to counter sink them otherwise it will catch on the motor
next do the same to the mechanism on the mini fitment and tap them to M3
next you can screw the plastic in to place remember to use short bolts so that they don't stick through too much
put back the rubber dampers that needed to be removed to get to drill the holes keep track of these as they are good at playing hide and seek
next drill three holes for the motor to attach to
now you can take some threaded bar and fasten it to the winder mechanism like so
align all the pins so that they go in the gaps between the rubber dampers and tighten the nuts up to hold the motor in to place
and that's all there is to it
a big thank you to elgringo from www.hundkoja.com for this guide
hope it is of some help to someone
michael
#2 Pooky
Pooky
  • 5,691 posts
Posted 07 May 2009 - 06:31 AM
Looks nice and simples to fit, going to need some pretty chunky door cards though!
#3 Marky Tizz
Marky Tizz
  • 2,434 posts
  • Local Club: LSMOC
Posted 08 May 2009 - 06:38 PM
great guide, FAQs plox :D
#4 stormintrooper
stormintrooper
  • 2,072 posts
Posted 08 May 2009 - 06:58 PM
surely this thing would be digging into your leg?
#5 Gizzum
Gizzum
  • 554 posts
  • Local Club: None atm
Posted 11 May 2009 - 10:20 PM
I have done something very similar. It doesn't get in the way as much as you'd expect. Its really the same as chucking a big speaker enclosure. Once you get used to it or make a door card to fit over it it won't be too bad.
My effort
It is a damn site cheaper than the kits you can get. It takes some effort to figure it all out but you get some great satisfaction watching it all work in the end!
