There is no point in putting expensive carpet into a leaky car or on top of a rusty floor, but in the last eight months Huey has had a new floor, arches repaired and doors refurbished and rehung, with new door seals. The new panels were sealed with 1-2-1 epoxy mastic before the car left the repair shop and the whole underside, sills and interior of the new crossmember were waxoyled.
So if he's going to have some home comforts that hopefully will last, now is the time.
First, out with the seats ... 4 bolts on the floor and three clip-off harness fastenings. All was well with the previous repairs, so I started with cheap foil-backed bitumen on the floor at the back and second skin spectrum sludge in front and as far up the engine bulkhead as I could reach
I didn't use the sludge thickener but applied several coats to get around 2mm thickness.
The door cards & other furnishings will come later
I also sludged the roof and bonnet. The roof lining is tatty but I may be able to rescue it.
