Power Expectations From This Engine Spec
7 replies to this topic
#1 jackson-minis
jackson-minis
  • 265 posts
  • Local Club: Minifinity, British mini club
Posted 01 July 2009 - 06:45 PM
1310cc +40 dished pistons
286 cam
twin 1.5" su's
3.44 diff
1-5-1 roller rockers
duplex timing gears
lcb, 2" single box
mg metro larger head ported and pollished with double valve springs
just looking for oppinions/advice on spec and power expectations please
cheers in advance, gaz.
#2 mattwho?
mattwho?
  • 844 posts
Posted 01 July 2009 - 07:54 PM
hum i would say at the wheel 30.2
:ermm:
#3 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 01 July 2009 - 08:04 PM
The above post is very helpful.
Probably about 85 at the fly, depends on the head work.
#4 jackson-minis
jackson-minis
  • 265 posts
Posted 01 July 2009 - 08:20 PM
cheers for the reply ouster, whats your oppinion on the spec would you change anything? is the cam the best option for a fast road engine?
mattwho? - if you can't comment sensibly please don't comment.
thanks gaz
#5 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 01 July 2009 - 08:46 PM
thanks gaz
Its a good cam but its going to give you a lumpy idle. Depends what type of driving you are going to be doing in the car?
#6 jaydee
jaydee
  • 8,565 posts
Posted 01 July 2009 - 10:17 PM
First of all 'd change the exhaust, as an lcb with 2" pipe and single box gonna improve only loudness. Go for a 1,75" exhaust from maniflow or a RC40 and about silencers, keep in mind that a single box system its very loud.
What clutch and flywheel you goin for? That setup sounds to me good for mid to high revs, dont expect power under 3k rpm.
#7 mike.
mike.
  • 6,176 posts
Posted 01 July 2009 - 10:30 PM
I'd loose those rockers. All they'll do is raise where the power comes in to an impractical point for driving in traffic and the like.
Put the money towards an ultralight flywheel and an RC40 exhaust...
#8 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 02 July 2009 - 09:51 AM
Loose the rockers and get an ultralite flywheel.
The Kent286 is a really nice cam. Tickovers a little lumpy but it pulls really well. I had the 286 in my 1293 and that went like a rocket.
Depending on the head work you should see 85bhp+
I had 85bhp at the wheels of mine, and that was a 1293, but the head was worked well and the ports were fully opened.
You dont need to get 1.5 rockers, look for pressed steel rockers, they are cheaper and they are more than capable of handling upto 120bhp
Also look into getting a 4pin diff, as the Diff is the weakest part of the gearbox.
Edited by miniman-pie, 02 July 2009 - 09:52 AM.
