Ive finally decided to try and sort out the horrible scuff marks on my rear windscreen and the rear side windows.
Looks like the previous tried to scrape ice off with a trowel sometime and theres nasty scratches (fairly deep) over the windows. Can i get these polished out?..i heard you can only get toughened glass polished this way?
If I can..who be a good company to go for..im in thw swindon area.
cheers
Window Scratch Removal
latestarter2
, Jul 01 2009 08:13 PM
8 replies to this topic
Posted 01 July 2009 - 08:13 PM
Posted 01 July 2009 - 08:42 PM
I would pop down to your local rac auto windscreens or simular place and ask them, they will tell you from experience, I asked them about grinding marks in a screen I brought second hand and they said I needed a new one.
Paul.
Paul.
Posted 01 July 2009 - 10:19 PM
Yes of course you need a new one...... however there are special substances for polishing windscreens, you can use Rhodite on a variable speed electric polishing mop set on slow....
Regards Martin
Regards Martin
Posted 02 July 2009 - 06:29 AM
Hi latestarter2,
I have found that Brasso (metal polish) has removed a small scuff from my wiper blade on the windscreen, however yours sounds far deeper than mine, it will take a long time polishing with whatever compound.
Ryan.
Ryan.
Posted 07 July 2009 - 02:40 PM
I have also heard that '0000' gauge steel wool can take out light scratching, but if you have deep gashes, then you may just be better to get a new window for it.
Nasty
Nasty
Posted 07 July 2009 - 08:58 PM
Bungle? Where's Bungle? He has some experience of polishing out scratches, I fink. Jeweller's rouge, was it?
Posted 07 July 2009 - 09:04 PM
yes that is what i have heard works
(never tried it my self on car glass)
Posted 07 July 2009 - 10:09 PM
try your local double glazing manufacturer/glazing firms i've seen some pretty deep scratches polished out with the right gear.they might be dubious doing front/rear screens because of the curve but most good firms will be able to do door and quarterlight glass easy.
