She Wont Run:(
8 replies to this topic
#1 luigi86
luigi86
  • 165 posts
  • Local Club: Tyred&exhausted mk
Posted 02 July 2009 - 03:52 PM
Hi all
Model: city e with 1275 engine
Year: 1986
Description of problem:
No spark! There is 8.6 volts at the coil when I turn the car over. the points are set and working correctly, yet there is no spark, it was working fine when I first got her. Left it for about a week or so and now she wont fire? we have a haynes manual and followed the instructions in there for troubleshooting with no luck. What can I do?
I have also tried a different coil that we know is working on my VW kit car.
distributor cap looks new, and all parts are clean and worked fine before I left her alone
please help!
Edited by luigi86, 02 July 2009 - 03:52 PM.
#2 luigi86
luigi86
  • 165 posts
Posted 02 July 2009 - 05:30 PM
any help appreciated, trying to get it going before the weekend!
#3 Phaeton
Phaeton
  • 1,055 posts
Posted 02 July 2009 - 05:32 PM
Are you running a ballast ignition system?
Alan...
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 02 July 2009 - 05:33 PM
what about the condensor have you swapped that.
Also you say you've tried a coil off a VW, are they also a ballasted system ?? The standard coil on yours is designed to work at a lower voltage.
Also what voltage is there with just the ignition switched on ??
#5 luigi86
luigi86
  • 165 posts
Posted 02 July 2009 - 05:39 PM
i dont know how you tell if its a ballast ignition system sorry?
not used to this old stuff.
Haven't changed the condensor... is this the likely problem?
will go and check the voltage with just the ignition on.
#6 luigi86
luigi86
  • 165 posts
Posted 02 July 2009 - 05:44 PM
just switched ignition on and checked the voltage, reading at 12v?
#7 Phaeton
Phaeton
  • 1,055 posts
Posted 02 July 2009 - 05:53 PM
With the ignition switched on take the top off the distributor & then open the points manually do you get a spark?
Alan...
#8 luigi86
luigi86
  • 165 posts
Posted 02 July 2009 - 05:56 PM
will give that a go now.
#9 luigi86
luigi86
  • 165 posts
Posted 02 July 2009 - 06:07 PM
no visible spark when opening the points manually with the ignition on
