Hi everyone,
I'm very new to the Forum and don't have much mechanical know-how, so please be patient!
My Mini is a bit of a mish-mash - a previous owner put the plates from a 1971 Morris Mini on a later chassis (I think early '90s) and has fitted a replacement 1275cc Metro engine, along with twin carbs.
I took it out for a run this evening, it was low on fuel, but still running very smoothly. As I neared the petrol station, I noticed the car lose power when I put it into third (as if I didn't have enough revs for that gear), but I dropped it back into second and it was fine from there until the petrol station.
I filled it with the correct fuel (unleaded), but a couple of minutes down the road noticed the same problem in third. I dropped it down into second, then first, but by this stage the car had lost all power and as I pulled into a layby it just cut out. Needless to say I had to be towed home!
When I turn the key, it turns over absolutely fine, but the engine just doesn't fire.
I had a fuel leak problem with it a few weeks ago (it was a leaky float chamber) but this was fixed professionally and the car has been running fine since.
Does anyone have any suggestions of things I can try before taking it down to the garage again?! Does it sound like a fuel problem or could it be anything else? A neighbour suggested that because it was low on fuel it could have pulled some gunk through from the bottom of the petrol tank.
Another thing worth mentioning is that I topped it up with some oil a couple of days ago. It was pretty cheap stuff, but it did say it was suitable for all petrol engines.
Any help would be very, very much appreciated!
Rob
Help! Engine Won't Fire
ellerington
, Jul 02 2009 09:00 PM
4 replies to this topic
Posted 02 July 2009 - 09:00 PM
Posted 02 July 2009 - 09:02 PM
A wire hasnt come loose on the dizzy or the coil has it?
Posted 02 July 2009 - 09:24 PM
Check all HT leads and coil then remove dizzy cap and check points gap and condensor check cap for cracks........
Don't think so - all seems to be secure
Posted 02 July 2009 - 09:37 PM
Is there a spark at the plugs?
