Vacuum Hose On Spi.
6 replies to this topic
#1 myblumini
myblumini
  • 87 posts
Posted 03 July 2009 - 11:50 AM
Where do vacuum hoses go on spi. I know ecu to fuel trap but rest. Mini spi 1995
Had problems with car emissions and had lost change but think I have found the problem.
My red one was attached to the fuel trap which and to air filter THIS IS WRONG . Can't see the one thats meant to go to the fuel trap. I have the one from fuel trap to ecu ok but where does the red one go and where does the one from fuel trap to inlet go? Think my one has falled off?.
Did notice at back of inlet injector there is a rubber pipe that comes out and goes back in to inlet again. Maybe somebody put it back on wrong.
No wonder car high emissions and now running bad after lambda changed.
Please help as could get car Mot again today if have time.
#2 murukan
murukan
  • 83 posts
  • Local Club: Wilts & Avon Mini Owners
Posted 03 July 2009 - 11:57 AM
There are 2, they come from right at the back of the inlet manifold. It's a tight squeeze to get at them because the bulkhead is so close.
Remove the air box and reach from above behind the inlet manifold and you should feel 2 nozzles, the vacuum hoses go on these.
One goes to the fuel trap and then from there to the ECU
One goes to the air filter box.
If an after market filter is fitted you can blank this one off.
#3 myblumini
myblumini
  • 87 posts
Posted 03 July 2009 - 12:01 PM
Can they go on any side at back of inlet or is it specific where they go.
By the way thanks for quick reply.
#4 blackbelt1990
blackbelt1990
  • 2,625 posts
  • Local Club: Minimus Maximus
Posted 03 July 2009 - 12:04 PM
if i remember correctly, if you're looking at the engine from the front of the car, red on the right, black on the left
:D
#5 myblumini
myblumini
  • 87 posts
Posted 03 July 2009 - 12:09 PM
:D
Thanks thats great away to try!
#6 myblumini
myblumini
  • 87 posts
Posted 03 July 2009 - 02:41 PM
Car passed MOT
Thanks a well happy man now. Wish I had found that out earlier.
#7 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 04 July 2009 - 04:56 PM
mine failed emisions.. meant to be 0.3 mine was 3.0 on C02... think my ecu has caput lol.
