Lcb Chosing The Right Manifold
Posted 04 July 2009 - 12:39 AM
1293 bore
286 scatter cam
stage 4 head
lightened and balanced flywheel
would it be a large bore lcb manifold??
and what material shall i look for as i have seen a few LCB in stainless does this have any more power gain? more durability?
any thing else i need to take into consideration???
thanks a lot guys
Dan
Posted 04 July 2009 - 08:23 AM
Posted 04 July 2009 - 10:28 AM
Stainless is more prone to cracking - and the lcb gets hot enough that effectively they 'never' rust - so normal steel will be fine. General opinion is that 1.75" bore is the one to use - I have my doubts and would personally use a 2" system. Maniflow have a great reputation - you won't go wrong with one of theirs!
I am running a LCB maniflow header with a 2" RC40 system, single box, its pretty good for gas flow, but I would think that a 1.75" exhaust system would be ok, I have found that with a 998 engine like I have, there is a slight flatspot lower down the rev range (as if the engine had a different cam changing the power band location).
I think with a 1275 or more a 2" system would be a good idea, as there is much more gas, especially with a scatter cam and a heavily ported head, also if you did upgrade further like I will be doing, the exhaust won't restrict performance.
Get a maniflow manifold (I have only heard good things about them) and a 2" system
I think there were some dyno tests on the RC40 single vs twin box system, might be an idea to search around for it
Posted 04 July 2009 - 10:49 AM
also do u think the price is right on this maniflow says 75+vat ? think they might have missed a 1 off the price
http://www.maniflow...._stage2_lcb.htm
also this is quite helpful
http://www.minimania...m?DisplayID=782
thanks again guys
Posted 04 July 2009 - 10:57 AM
thanks guys i have been doing a lot of looking around and found some other pages and thought if any one else is doing the same thing as me i can put it up for them as well
also do u think the price is right on this maniflow says 75+vat ? think they might have missed a 1 off the pricetrying to order one but there not answering the phone
thanks again guys
Its about £80 on minisports:
http://www.minisport...info_LM004.html
And about another £125 for the rest of the system:
http://www.minisport...nfo_LS005A.html
That £75 would be just for the exhaust manifold
