Radius Arm Repair
Posted 22 July 2009 - 07:09 PM
have had a rattling sound coming from the back end of my mini for about 6 months now and have finally narrowed it down to the radius arm bearing.
my plane was to fit this kit
http://www.minispare...=... REPAIR KIT
so my question is has anyone done this and if so , how easy is it to do ?
thanks
Posted 22 July 2009 - 07:22 PM
Posted 22 July 2009 - 07:37 PM
The other difficulty is getting the old bushes out, especially the needle roller one. Usually one ends up smashing the bearing end flange, getting all the rollers out, then using a sharp centre punch down the outside of what's left of the bearing casing until it can be pulled out.
Make sure you fit the plastic grease-retention sleeve between inner and outer bearings.
Posted 22 July 2009 - 08:25 PM
It cost me about £40 in garage labour to replace.
I discovered my car was crabbing due to a worn radius arm.
Posted 22 July 2009 - 09:21 PM
The plain bush has to be reamed out after installation. Reamer size is 13/16" and it needs to be quite a long reamer.
Hi. I know this isn't my topic, but could do with some help with what you just said. I'm currently re-doing pretty much all the suspension and brakes and whatever on my brothers mini which has been sat around for a while. Just got to stripping the back end off and about to do this job. When you say "the plain bush has to be reamed out after installation", what do you mean?? No idea what reaming is, ha. Thanks,
Carl
Posted 22 July 2009 - 09:34 PM
The reamer size is 13/16".
It's a lot easier than it sounds.
You turn the reamer and push it by hand using a crank handle arrangement. Some people use a power tool to push it through with, but I've found that doing it by hand is better. It turns very slowly, not quickly like a twist drill.
I hope this explains it OK.
Peter
Posted 23 July 2009 - 01:26 AM
http://home.mindspri...ArmReamer01.jpg
Posted 04 June 2012 - 11:39 AM
Edited by 0138dave, 04 June 2012 - 11:42 AM.
Posted 04 June 2012 - 11:50 AM
We use an adjustable reamer like the one pictured on the right to ream the bushes to the right size.
Posted 04 June 2012 - 11:59 AM
See the picture I linked in my 2009 post. You will notice the pilot on the reamer shaft towards the right side of the picture.
Posted 04 June 2012 - 12:19 PM
Personally, I'd avoid adjustable reamers: they are cutting tools and as such remove, and need , more material than their actual diameter indicates. I have got good results "grinding" similar bushes with fine production paper wrapped round a suitably sized socket, but not on something as long as a radius arm, with the incumbent difficulties of keeping it concentric.
Posted 04 June 2012 - 04:45 PM
Unless you are certain about what you are doing on this safety critical part, as others have said, by the time you have bought the tools etc, it's easier, quicker & maybe less costly to go recon.
Best of luck whichever way you go.
Regards
Steve
Posted 04 June 2012 - 05:08 PM
