Rover Mini Studio 2:
1991:
Heater only blowing out cold air, and it seem not to warm up after drive a while???:
Heater Only Blowing Out Cold
boddz
, Sep 16 2009 03:35 PM
5 replies to this topic
Posted 16 September 2009 - 03:35 PM
Posted 16 September 2009 - 03:46 PM
Hi there
welcome into the club
The most common issue is with the heater valves as they normally get stuck open or closed, as yours is a later mini its a black plastic sort, you can get a replacement at minispares, also check that the water level in the rad is topped up as well as if there isn't any water to pump around, it won't get pumped around!
Posted 16 September 2009 - 03:57 PM
You've likely got the same setup as me.
As m1tch says, heater valve (attached to the other end of the heater cable), check that this moves correctly. It can get seized, and can be freed up with some WD40 and a clean up.
If the heater valve is moving ok (with the heater cable), the other possibility you could have is that the heater matrix has gotten blocked.
This is my current problem. My heater valve is permanently "on" at present, and I still don't get any hot air. It's lower down my priority of problems at present and will be sorted at some point. I've heard it's possible to flush things out with a hose, or use some descaler possibly. Perhaps someone else could elaborate.
Posted 16 September 2009 - 04:25 PM
Hi just may be worth checking the thermostate before you go too far, easy check is to remove it and run engine see if you get hot air.
Posted 16 September 2009 - 05:04 PM
The above points are what i would do first. Also it would probably worth cleaning out the heater matrix, its suprising how much brown muck is in there.
James
James
Posted 16 September 2009 - 05:27 PM
i'd plump for the heater tap being the problem. take it off, spray with WD40 until it moves freely and replace. Might be worth taking the other heater hose off and firing water through the heater matrix via this pipe, basically reverse flushing the matrix.
unless the heater pipe comes off the thermostat housing and the thermostat has broken up, i cant see it being the thermostat as your car would be overheating by now.
