A Series Engine Numbers
85 replies to this topic
#16 minimarco
minimarco
  • 1,950 posts
Posted 30 January 2007 - 05:17 AM
found this on the minimania site
kind of messy though
#17 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 30 January 2007 - 09:16 AM
They are all in there...
#18 stumpf
stumpf
  • 18 posts
  • Local Club: staffs minis
Posted 05 March 2007 - 03:35 PM
Just got a mg engine is it ?
12hc01aa ........ :D
and if it is not an mg wots the price difference
Edited by stumpf, 05 March 2007 - 03:41 PM.
#19 TOMMO0302
TOMMO0302
  • 1,688 posts
Posted 04 April 2007 - 03:06 PM
I cant see 12H 959AA on the chart, should be a 1983-1990 MG Turbo engine i think...can you confirm?
#20 hlynur
hlynur
  • 62 posts
Posted 24 August 2007 - 01:42 PM
Does anyone have knowledge of numbers for A-series that were fitted to the Austin/Morris 1100/1300 range?
I have a block from a 1300GT and one from a 1300. Both have been skimmed at some point and the numbers drilled off but I have one of the plates, numbered 12H-159-H62063.
I know which block is the one from the GT and that's the one I'm using. I'd like to confirm the number so I can get it changed with the DVLA when I drop it in to the car. The log book is long since gone as you would imagine...
Edited by hlynur, 24 August 2007 - 01:43 PM.
#21 hlynur
hlynur
  • 62 posts
Posted 24 August 2007 - 07:49 PM
OK, I confirmed that 12H-159-H62063 is the 1300 engine and not the one from the 1300GT. Astoundingly we managed to track down the log book for the 1300 in my grandmothers house. So 12H159~ denotes a solid block 1275 that was fitted to a blmc 1300 and my engine is still unidentified. But hey, if the 1300 was never officially scrapped then maybe the GT logbook is still kicking around somewhere as well...
#22 rallymini
rallymini
  • 47 posts
Posted 02 September 2007 - 03:11 PM
I've had a look through all the links and established my engine is a 1275 recon unit, but can't find the exact number RKM1113E. Any ideas?
#23 wmkccwhite
wmkccwhite
  • 409 posts
Posted 02 September 2007 - 07:41 PM
Hiya,
Can you help me find out the year and size of this engine. The number is BHM 1667E 149926. There is also another number on the side that is WFM 1024 NW.
Any help would be great.
#24 slick
slick
  • 158 posts
Posted 09 September 2007 - 04:14 PM
got 2 mini's
1 on the road,
1 off the road
but a bit stuck with the engine numbers.
1) 99he2012613
2) H791pz44368
Any info will be very much appreciated
just fount this for engine 1,
Flat top pistons with press fit wrist pins, Lead-free cylinder head
99H/E20 or E21
shows its an A+
Edited by slick, 09 September 2007 - 04:18 PM.
#25 minicol
minicol
    Starting My Mini Up
  • 1 posts
Posted 11 September 2007 - 09:31 AM
Hi Guys
Just found yor site as it may be some help to me.
Can anyone identify my engine
On the stamp it has 12H694AA 044611
Many thanks
Colin
#26 mini16
mini16
  • 340 posts
Posted 13 November 2007 - 09:16 PM
i have bought an engine, just to fined it has no engine numbers on the top of the block, seller said they came off when it had a bore skim, and has now give me the number, but i cant match it up with any thing on the chart, its a metro turbo 1275 engine, number is 12h199h8677
? cheers
Edited by mini16, 13 November 2007 - 09:17 PM.
#27 riley
riley
  • 56 posts
Posted 21 November 2007 - 01:06 PM
I have just bought an engine with engine number 12HE25 and cylinder head 12G94
was told it was an MG can anyone help confirm this
#28 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 21 November 2007 - 04:20 PM
If you look in the list at the top you'll see that it's down as a unleaded high compression engine... but is not detailed as comming from an MG... however the only difference between this engine and an MG Metro engine will be the cam... everything else is the same including the head, as ALL unleaded 1275 heads are the same.... the larger valves used by the leaded metro were dropped ( pardon the pun ).
#29 CraigyBoy
CraigyBoy
  • 407 posts
Posted 19 December 2007 - 06:54 PM
Only just found this valuable page, I have a 1275 A+, from a metro, i dont know what year because it's been in my uncles shed for a few years. But it's got an unusual engine number on it. I know it's from a metro because it still had original metro mounts on it.
BHM145.....513.
anybody know what it could be.
could it be an engine that has been rebuilt and given a new block number, or anything else?
stupid me just looked at this page agen and seen a similar number,didnt see that before,,,,,,,,,,,spooky.
Edited by CraigyBoy, 19 December 2007 - 06:55 PM.
#30 BikerGran
BikerGran
    Just On Tickover
  • 6 posts
  • Local Club: Jurassic Coast Minis
Posted 27 December 2007 - 02:48 PM
I've just bought a mini engined automatic trike, and need vto know a bit more about the engine.
Looking on your list the nearest number is 99H 791 which tells me it's an A series 998 with leaded head (v useful to know!) from a mini 74-on. My actual number is 99H 79 ZPH - is there any way I can use this to find out what year the engine was manufactured?
