How To Get The Selector Rod/gear Linkage Off The Gearbox
9 replies to this topic
#1 L1979
L1979
  • 40 posts
Posted 07 February 2010 - 01:46 PM
HI!
I'm refurbishing my gearbox but to get the differntial of I have to get the gear linkage arm off first, but dont now how xD
There's a pin which holds the linkage in place with the gearbox gear switcher(don't know what it's called) I've tried to hammer it out and screw it out but it does'nt work
Very happy for replys
cheers!
A proud mini owner :thumbsup:
Edited by L1979, 07 February 2010 - 01:53 PM.
#2 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 07 February 2010 - 01:53 PM
Ideally you'll need a roll pin punch or something very similar that will drift the roll pin out of the selector rod joints. Putting the car in reverse helps get the best access so you can effectively swing a hammer.
Also pack the selector rod with a piece of wood, so the rod doesn't bounce around whilst you're striking it with a hammer. It also helps concentrate the force to shift the roll pin too.
#3 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 07 February 2010 - 01:54 PM
Oh and make sure the Mini is securely supported on axle stands or ramps whilst you're working under there.
#4 L1979
L1979
  • 40 posts
Posted 07 February 2010 - 01:56 PM
haha just finished my editing when I saw your answear xD
Ok so its just to hammer it out?
Edited by L1979, 07 February 2010 - 01:56 PM.
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 07 February 2010 - 02:04 PM
Yes - but with the correct size punch. Nail/screwdriver etc will just mess it up!
#6 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 07 February 2010 - 02:12 PM
Yes you need this: -
Click Me.
#7 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 07 February 2010 - 02:56 PM
Or get yourself this set
http://www.screwfix....Pin-Punches-5Pc
One of them is the perfect size for that pin and they all come in handy for numerous jobs on the mini! >_<
Had mine a while now and ive lost count of the number of times it has come in useful!
Edited by Stewart_GT, 07 February 2010 - 02:57 PM.
#8 L1979
L1979
  • 40 posts
Posted 07 February 2010 - 06:28 PM
Thanks for your replys, I got it out with a pin punch
how do I put it back on afterwards?
Edited by L1979, 07 February 2010 - 06:28 PM.
#9 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 08 February 2010 - 08:37 PM
Tap it back in with a hammer. Just make sure the holes are lined up properly.
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 08 February 2010 - 10:42 PM
If you're going to refurb the box, then you will need a set of parallel punches, 1/8" upwards.
