Electronic Ignition
Posted 07 February 2010 - 11:28 PM
Posted 07 February 2010 - 11:34 PM
Edited by samsernie, 07 February 2010 - 11:34 PM.
Posted 08 February 2010 - 01:10 AM
Posted 08 February 2010 - 06:31 AM
I brought 2 of the old kits for different minis from here http://www.mm-4x4.co...-kit-2721-p.asp
That link shows the old kit but probably worth asking if they have the updated version
the 2 minis they are fitted to have done probably 30,000 miles each since fitting trouble free.
Posted 08 February 2010 - 08:15 AM
Posted 08 February 2010 - 08:25 AM
Posted 08 February 2010 - 11:05 AM
Posted 08 February 2010 - 11:19 AM
Heres a picture of the new kit
and heres the new instructions...
Posted 08 February 2010 - 11:27 AM
I've just emailed MM 4x4 a minute ago to ask about that, but it looks like I'll go ahead and order it now.
Edit: Is the only change the fact that there is now no rotor arm? If so, would it help for me to buy the old kit with a new rotor arm in it, as mine is looking a little worse for wear?
Edited by The-Womble, 08 February 2010 - 11:30 AM.
Posted 08 February 2010 - 11:28 AM
The black wire you do connect to the negative on the coil.
They are sold for Landrovers which run a non ballast system so designed to run at 12 volts.
Edited by lrostoke, 08 February 2010 - 11:29 AM.
Posted 08 February 2010 - 11:32 AM
I take it I would be fine?
Posted 08 February 2010 - 11:34 AM
Posted 08 February 2010 - 11:36 AM
I don't think they stock the "old kit" anymore - even Britpart themselves are showing the "new style" kit.
One thing those instructions don't mention is on a mini you should run a new 12v ignition fed live to the red wire on the module, and don't connect the red wire to the coil.
What would you then put on the +ve connection on the coil or do you leave it blank?
Edit: When was the change over for the Ballast systems?
Edited by Twincam, 08 February 2010 - 11:44 AM.
Posted 08 February 2010 - 11:46 AM
Do Minis' system not run at 12V?
Mini ignition comes in 2 main flavours ballast and non ballast, ballast came in around 1984
if the coil as a white/pink wire connected to the positive then its ballasted and will be running at around 8 volts
If no white/pink wire then non ballast and will be a 12v system.
If you have the ballasted system then you need a new 12v feed to the red wire on the module, do not connect the red wire to the coil
If its non ballasted then the red wire can be connected direct to the coil.
In both cases leave the standard car wiring connected to the coil, no need to disconnect anything.
Edited by lrostoke, 08 February 2010 - 11:48 AM.
Posted 08 February 2010 - 12:03 PM
No worries, I was a tad scared when I bought it and a member on here told me I needed the Rotor Arm...
Right ok, so I'll just buy the kit and buy a new rotor arm at the same time
Thanks a bunch guys....really helpful
Edit: ^ That sounds really sarcastic, but it's not
Edited by The-Womble, 08 February 2010 - 12:04 PM.
