Blown Head Gasket, I Think...please Help
Posted 08 February 2010 - 10:42 AM
I checked the oil last night to see a yougurty frothy cream coloured substance gunking up around the cap and everywhere else. I know this is a blown gasket sign but so far no smoke or even lack of performance! If I hadn't of took the cap of I would have never known. I have done an oil change and topped her up for now but I use the car for work so I need it to be fixed asap.
Am I right in thinking this is a gasket as I am no expert!?
Anyone know of any rough prices of what this will cost to fix?
Posted 08 February 2010 - 10:57 AM
Posted 08 February 2010 - 11:00 AM
If no power loss or other problems it could just be condensation not evapourating off. Try cleaning out the breather pipes.
Cold weather you will get condensation in the engine, on short runs the engine won't get hot enough for long enough to evapourate it off.
Posted 08 February 2010 - 11:23 AM
Im trying to get hold of a garage that will do a compression test without ripping me off. Im really new to mechanics...
its like a creamy foam...
Posted 08 February 2010 - 11:29 AM
Posted 08 February 2010 - 11:31 AM
Posted 08 February 2010 - 11:34 AM
Could always buy a Compression test kit and attempt it yourself... Its actually not that hard (and you'll have the kit to use after)
idea, I will look into them, I dont know what a compression kit even looks like though could you link an example?
Posted 08 February 2010 - 11:37 AM
£19
doddle to use, unscrew spark plugs, screw gauge adaptor in, crank the engine over on the starter a few turns, write down the reading. Do that for all 4 cylinders
Edited by lrostoke, 08 February 2010 - 11:38 AM.
Posted 08 February 2010 - 11:41 AM
Posted 08 February 2010 - 11:43 AM
Well worth it I say.
Edited by Twincam, 08 February 2010 - 11:44 AM.
Posted 08 February 2010 - 12:23 PM
Assuming compression is about the same, and reasonable on all four cylinders, consider an oil and filter change, and monitor the condition of the oil and coolant.
Dave
Posted 08 February 2010 - 06:22 PM
