Water In Oil
11 replies to this topic
#1 onlymelloyd
onlymelloyd
  • 276 posts
  • Local Club: looking...
Posted 08 February 2010 - 06:20 PM
I have just done a head gasket change on my 1994 1275 stage 3 tuned carburettor engine due to finding the dreaded milky substance under the oil filler cap
I changed the head gasket flushed the system and ran the car for about twenty minutes before using it. I have done about 7 miles since the change and thought I would double check everything was ok as when I took the head off on sunday the payen head gasket that was previously fitted was not blown i figured the reason it had blown was because of fairly loose studs that came out all too easy when removing the head. I once again opened the oil filler cap to find more milky oil.
I have no idea where this could be coming from. the block and head are both fairly newly refurbished and upgraded. infact modifications not even 6 months old.
also the car seems to be running better today than it was before.
why is there water in my oil?
#2 mini13
mini13
  • 3,811 posts
Posted 08 February 2010 - 06:36 PM
do you do a lot of short journeys?
are you using tat green duckhams oil?
#3 onlymelloyd
onlymelloyd
  • 276 posts
Posted 08 February 2010 - 06:39 PM
5 miles to work 5 miles back. i try to run it longer a couple of times a month.
Im running castrol classic 20w50.
#4 .998TANGO.
.998TANGO.
  • 290 posts
ive got exactly the same proplem.. cant figure it out. >:thumbsup:
im using that green oil.
#5 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 08 February 2010 - 06:44 PM
condensation is a reason for this sort journeys and engine not getting warm
dave
#6 onlymelloyd
onlymelloyd
  • 276 posts
Posted 08 February 2010 - 06:49 PM
dave
i do around about 5 miles a day in traffic. I woulda thought the engine gets plenty warm enough when its running for 30-40 mins per run.
#7 mini13
mini13
  • 3,811 posts
Posted 08 February 2010 - 06:51 PM
as above short journeys can cause this,
also the green classic oil is really prone to it, it used to do it even on long jouneys in mine.
try some millers oil in there the CTV i'm using is really good.
#8 onlymelloyd
onlymelloyd
  • 276 posts
Posted 08 February 2010 - 06:56 PM
if its condensation would it look like someone had poored a bottle of milk into the rocker box. or would it just have a slight spotting in the oil?
#9 mini13
mini13
  • 3,811 posts
Posted 08 February 2010 - 07:00 PM
when i had that green oil in mine thats what it looked like,
massive load of thick creamy gunk in there, it took about a month for it to go after i changed to a different oil.
#10 onlymelloyd
onlymelloyd
  • 276 posts
Posted 08 February 2010 - 07:04 PM
I am running it with castrol classic 20w50. i used to run it on penrite but it started getting expensive. I never noticed this problem before with the penrite. will it do any damage to the engine with it running how it is now.
#11 mini13
mini13
  • 3,811 posts
Posted 08 February 2010 - 08:42 PM
I cant see it doing any harm, but its a bit irritating when your doing the tappets.
#12 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 08 February 2010 - 08:47 PM
Take it for a good long hard run soon. That should help.
