Mpi To Carbs
8 replies to this topic
#1 sir Jake the brit
sir Jake the brit
  • 227 posts
  • Local Club: looking for one
Posted 08 February 2010 - 07:23 PM
HELLOHAA PEOPLES i need help!
i've (over the last 3 years) been having my mpi jcw mini restored and modded somewhat quite expensively!!
BUT i wanted to keep it mpi and have a healthy 1425mini mpi with something like an omex running it.
so, i've decided to go carb as i have a guy who specializes in omex etc that there setup wont run it anybetter!! so i need to set it up on carbs
my question is. what do i do about mot's!! not wanting to go to some bent guy and i dont want (if it can be helped) to nick plates of a scrapper and make out my engine is older than it is!! lol!!
any help / ideas would be epic! thanks!
#2 sir Jake the brit
sir Jake the brit
  • 227 posts
Posted 08 February 2010 - 09:24 PM
no idea then?? have i put this in the wrong section??
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 08 February 2010 - 11:57 PM
You need to change the whole engine. To avoid any possible trouble at the MOT you need to retain proof of the age of the replacement engine, in the form of a receipt and documents that show the engine number and the year of the vehicle it came from. Ideally you need proof of the VIN of the vehicle it came from on the receipt too because the MOT computer uses that number to identify what emissions test your car then requires. If you don't have the VIN, the tester has to work it out for himself. Your car will be emissions tested on the age of the engine.
You waited 2 whole hours before you got bored? Really? This has been covered many times before, the information is all here already.
#4 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 08 February 2010 - 11:59 PM
you can stamp an old engine number into it. :thumbsup:
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 February 2010 - 12:12 AM
Which of course is illegal and is exactly what the OP was asking how to avoid in his first post! In any case, since MPi blocks are stamped and not plated with an engine number it would be quite tricky to forge without getting the block skimmed.
#6 rick.spi
rick.spi
  • 1,686 posts
Posted 09 February 2010 - 12:14 AM
well the only way is to get an older engine then... surely?
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 February 2010 - 12:21 AM
Yes, sorry I realise that it might not have been clear from my first post that this is what you need. An older replacement engine, not just a replacement. An engine from a time before there was a need to pass a cat emissions test.
#8 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 09 February 2010 - 07:23 AM
older engine block, and a lot of modifications
dave
#9 rick.spi
rick.spi
  • 1,686 posts
Posted 09 February 2010 - 04:31 PM
no your quote is clear :o i just didnt read it fully last time i just did a quick skim lol, ive just read it fully. :thumbsup:
my mistake.
Edited by rick.spi, 09 February 2010 - 04:32 PM.
