Mg Metro 1275 Issues!
Posted 08 February 2010 - 07:42 PM
cheers
dan.
Posted 08 February 2010 - 07:50 PM
Posted 08 February 2010 - 08:01 PM
Posted 08 February 2010 - 08:03 PM
what lewis has said is fine but you will need to make sure your heater valve is contantly open, which is fine in the winter but a bit too much for the summer
mine is constantly open lol but when summer comes, ill be drillin the stat and fitting an alloy 2 core rad to aid cooling!
Posted 08 February 2010 - 08:19 PM
Posted 08 February 2010 - 08:22 PM
yes it is is bloked off, so if i drilled it out for a heater tap. could i fit a water pump with a take off for a bypass hose and link it to the take off under the thermastat housing??
you wouldnt need to, as you would run it through the heater, to the small outlet on the bottom rad hose, unless ur not having a heater in your mini...
Posted 08 February 2010 - 08:27 PM
but if you ran it just through the heater you would have to have the heater on all the time no?
Posted 08 February 2010 - 08:46 PM
Drill some holes in the thermostat so you have a bypass.
Posted 08 February 2010 - 08:52 PM
You drill the hole in the bottom left corner head and put your heater valve onto it. Then you put the pipe on the left of the bulkhead that leads into the car onto the heater valve. That way you use the heater cable in the car to tuen it on or off.
You then link the right hand side pipe into the radiator bottom hose.
You dont need a bypass, if anything its good that youe havent got one as that way it wont split on you. Just drill some holes in the stat or buy a stat from halfords with the bypass in it.
Edited by lawnmowercrap, 08 February 2010 - 08:53 PM.
Posted 08 February 2010 - 09:31 PM
do you mean on the water pump to the bottom of the head?MG metro 1275 and was wondering what to do about cooling, as in theres no by-pass hose.
Posted 08 February 2010 - 10:29 PM
Posted 08 February 2010 - 11:14 PM
Posted 08 February 2010 - 11:40 PM
You only need one 1/8" hole in the rim of the stat - just to ensure a little water can circulate. Makes for a MUCH faster and better heater - especially if you use an 88 degree stat!
How's that then? Drilling the stat means that water is always going through the radiator and therefore takes longer to get up to temp.
I didn't want a troublesome bypass between the block and water pump, so after seeking advice from here, went for a system using a sandwich plate under the stat housing, ran hose through my inlet manifold and back to a tee piece in my bottom hose. I also fitted an 88 deg stat at the same time. Now with my 2 core rad it gets up to temp in a matter of minutes and stays there
Posted 09 February 2010 - 09:33 AM
Thats what im going to do, but running it direct to the bottom hose.
