Cylinder Head Stud Hole Size?
2 replies to this topic
#1 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 08 February 2010 - 08:12 PM
When i removed the head on my 1275 Metro engine the front centre stud was a real sod,tight is an understatement. Now I am porting it etc I went to clean that hole out but it is smaller, at 10mm where the others are nearer 11mm. Is this some kind of positive location method or should I open it up.While I am on,some suggestions for a needle to start with would be helpful to suit this spec:- Well ported out and valves deshrouded,35.6mm inlet valves,Maniflo LCB and 1 3/4 id twin box system,1.5 rockers, cleaned out iron oiginal inlet manifold obviously separated from exh,10:1 CR,HIF 44,std air filter and case.What may it produce? hp and torque.
#2 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 08 February 2010 - 08:24 PM
Yes, it is for positive location - DO NOT OPEN IT UP. Clean out the gunk, but no more; its meant to be a tight fit. Re needle, perhaps someone else could give you a starting measure...
Ryan.
Edited by L400RAS, 08 February 2010 - 08:25 PM.
#3 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 08 February 2010 - 08:58 PM
OK thanks Ryan, I thought that maybe the case.It needs to be positioned properly as the gasket is extremely close to the edge on some cylinders,not due to deshrouding-it was already like that.BDL or BDK came up on search facility
