Megajolt - Tps Or Map
Posted 08 February 2010 - 09:11 PM
Ideally I would like to use the MAP sensor as it is much easier to fit.
Problem is:-
The engine has a Kent 286 cam in it.
Megajolt suggests that for extreme cams that a MAP (Manifold Air Pressure sensor) is not the best option as the cam can cause a a pulsing effect in the manifold.
Question is does anyone know if this cam will cause problems? - Or do I have to fit the throttle position sensor to the carb??
Cheers in advance
Posted 08 February 2010 - 09:14 PM
Posted 08 February 2010 - 09:15 PM
I'd go for MAP if I were you, I think you'd have to have a rather extreme motor to actually need to use TPS.
Posted 08 February 2010 - 09:16 PM
Posted 08 February 2010 - 09:17 PM
Posted 08 February 2010 - 09:23 PM
Posted 08 February 2010 - 09:25 PM
Posted 08 February 2010 - 09:31 PM
Posted 08 February 2010 - 09:36 PM
Posted 08 February 2010 - 09:47 PM
lets take the TPS out of the equation firstly, as you 'floor' the throttle the butterfly opens as fast as you put your foot down, but the float, because it's dampend it will slowly open as the engines need for air increases along with the RPM for now I'll call the the 'float catchup time' (I just made the name up)
so while using the TPS the TPS will read FULL THROTTLE even though the float (because of the catch up time) is still not fully open IE not having full throttle.
Dose that help?
Posted 08 February 2010 - 09:58 PM
Posted 08 February 2010 - 10:00 PM
Posted 08 February 2010 - 10:02 PM
Decision made - Will go for a MAP sensor I think - They always do a kit for TPS conversion if it is giving problems.
Posted 08 February 2010 - 10:03 PM
Posted 08 February 2010 - 10:04 PM
Nice info though cheers
