It says that i need to use a 12 volt voltmeter and test between the the low tension wire (sw +) and earth. But the manual is for a negative earth car, so if i connect the wire from the sw to earth (which is positive) it wont work will it?
What do i need to do? the thought of positive earth is scaring me
xxx
