Fitting Hi-lo's Without A Compression Tool?
Posted 08 March 2010 - 03:23 PM
I previosuly started a thread regarding a problem i had where i stripped the thread on the suspension cone when using a compression tool.
I am not buying another compression tool for £30 and i don't want to buy another cone for £30 either.
I'm sure many other people on here would like to know how hi-lo's are fitted without a compression tool! .....as i know it can be done via removal of the top arm.
Please can someone help me get my hi-lo's fitted and use this thread for future reference to anyone wanting to fit hi-lo's without splashing out on unnecessary tools.
I will look forward to people's suggestions as to how they did it.
Thanks a lot,
Mike
Posted 08 March 2010 - 03:35 PM
I don't think it's possible without a compression tool...
Nowadays almost all cones are metric thread, o you can but a cheaper compression tool for just 15 quid, or you can always make you tool yourself, but its necessary for the job.
Posted 08 March 2010 - 03:38 PM
Posted 08 March 2010 - 03:40 PM
Posted 08 March 2010 - 03:42 PM
Posted 08 March 2010 - 03:44 PM
i dont mean run it with a cut cone!!! thats only for the stupid, you can cut the cone to pull it out if your CAREFULL
And then you need a compression tool to get the new one back in...
Posted 08 March 2010 - 03:46 PM
Posted 08 March 2010 - 03:47 PM
The rubber cone loads tons of compression through the alloy trumpet, if you break it in pieces, it will damage the top arm and could be very harmful for you working on the mini.
Posted 08 March 2010 - 03:49 PM
Posted 08 March 2010 - 04:04 PM
From what i gather, can't you remove the top arm via the balljoint, undoing the two nuts and removing the pin, and by undoing the shock absorber?
Then (again, from what i have gathered), don't you take the cone, trumpet & knuckle out etc, put the cone back in with the hi-lo (and new knuckle) wound down to its smallest? Then put the top arm back with the pin etc and re-connect everything.
Someone mentioned applying pressure to the top arm to get the pin back in.....and they didn't use a compression tool? I don't know if he meant hand pressure or what?
Posted 08 March 2010 - 04:07 PM
Posted 08 March 2010 - 04:35 PM
but the long and short of it is, there's no substitute to using the proper tools, and cone compressors are not that expensive.
Posted 08 March 2010 - 04:38 PM
Posted 08 March 2010 - 04:50 PM
I really don't see how it is possible to fit the new trumpet (or hi-lo) without the one compressed and it sounds foolish to attempt it without the correct tools.
Edited by Cooperman, 08 March 2010 - 04:51 PM.
