Speedo Wiring
8 replies to this topic
#1 ohsuchislife
ohsuchislife
  • 200 posts
Posted 08 March 2010 - 04:23 PM
i think im having a mad blonde moment .. changing my speedo to center binnacle .. but having problems with the ignition and oil presure lights .. am i going wrong or am i missing something .. w/b oil pressure light, straight to blub , the same as the ignition warning light .. but they both dont come on ...
anyone know where i am going wrong
#2 ohsuchislife
ohsuchislife
  • 200 posts
Posted 08 March 2010 - 04:25 PM
i found out looks like you cant join the turn warning together ... or can you .....
any ideas
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 08 March 2010 - 04:29 PM
No you can't
The signals for the independent left and right tell-tales is taken after the indicator switch but for the single tell tale it's take from the flasher unit.
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 08 March 2010 - 04:43 PM
You could do a slight modification like I did
Use the left and right orange lights either side of the clock as the indicator tell tales.
The top green is now oil warning
rest stay the same
#5 ohsuchislife
ohsuchislife
  • 200 posts
Posted 08 March 2010 - 06:17 PM
rest stay the same
how did you wire your ignition and oil presure lights up ...just cant get mine working ...
#6 lrostoke
lrostoke
  • 6,923 posts
Posted 08 March 2010 - 06:25 PM
For ignition you need an ignition fed 12v supply (white wires) to one wire on the bulb, the other wire you connect to the small terminal on the alternator.
This wire should already be in the dash loom that went to your old clocks. (brown/yellow)
Oil pressure warning is the same, ignition fed 12v supply (white wires), with the other terminal going to the sender on the engine via the loom (white/brown)
Edited by lrostoke, 08 March 2010 - 06:30 PM.
#7 ohsuchislife
ohsuchislife
  • 200 posts
Posted 08 March 2010 - 07:02 PM
so i need twin lead bulb holders ... or bulbs with twin leads ...
thanks again for your help ..
bloody crap with electrics
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 08 March 2010 - 07:05 PM
yes, thats correct single lead holders won't work for ignition and oil light, although they are fine for the clock illumination
Edited by lrostoke, 08 March 2010 - 07:07 PM.
#9 ohsuchislife
ohsuchislife
  • 200 posts
Posted 08 March 2010 - 07:16 PM
thanks mate .. just worked it out found a loom on the net and found the twin bulb holders ...
thanks for all your help mate ...
just could not get my head around it
