Welcome Guest ( Log In | Register )
> Don't give out incorrect advice - if you don't know the answer, don't post!
Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action.
Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
This is why we ask that only first-hand and factual information is posted in reply to peoples queries.
If you are not 100% certain of your reply, be sure to point out your uncertainty.
Reply to this topicStart new topic
> Water Pump Spacer
beentheunseen
post Mar 8 2010, 06:33 PM
Post #1
Group: Members
Member of a Local Club?: Notts about Minis
Hey guys,
just had a fan belt failure, and looking at the pulleys I think I must have got something wrong when i was assembling the engine as the pulleys don't line up... Where should the fan spacer go? Between the pulley and the water pump, or between the pulley and the fan?
Go to the top of the page
+Quote Post
Grayedout
post Mar 8 2010, 07:12 PM
Post #2
Group: Members
Between the pulley and the pump.
+Quote Post
Wilson1330
post Mar 8 2010, 07:14 PM
Post #3
Group: Traders
Member of a Local Club?: TMF
QUOTE (Grayedout @ Mar 8 2010, 07:12 PM) *
wrong, the spacer goes between the pulley and the fan.
+Quote Post
Grayedout
post Mar 8 2010, 07:20 PM
Post #4
Group: Members
Not on my car it doesn't !
+Quote Post
beentheunseen
post Mar 8 2010, 07:22 PM
Post #5
Group: Members
QUOTE (Wilson1330 @ Mar 8 2010, 07:14 PM) *
Yeah, seems like I had it between the pulley and the pump when i had the failure, so i moved it to between the fan and the pulley. Still doesn't look quite right though... Another question, should the alternator bolt directly to the pump and mounting bracket, or should there be spacer washers inbetween?
+Quote Post
R1minimagic
post Mar 8 2010, 07:45 PM
Post #6
Group: Members
The later cars e.g. MPi have 2 spacers, one after the pump and one after the pulley.
+Quote Post
beentheunseen
post Mar 8 2010, 08:07 PM
Post #7
Group: Members
It's not an MPi, its a 1989 998 with just the one spacer...
+Quote Post
Pooky
post Mar 8 2010, 08:22 PM
Post #8
Group: TMF+ Member
I would have said between pump and pulley too, thats where mine is. What would be point in having it outside the pulley? To push the fan further into cowling I suppose. Just put it where ever gets the fan belt straight. I think you can ones in different thicknesses.
+Quote Post
beentheunseen
post Mar 8 2010, 08:49 PM
Post #9
Group: Members
QUOTE (Pooky @ Mar 8 2010, 08:22 PM) *
I couldn't quite get the belt quite straight with either arrangement... Just going to try it between the fan and pulley as that seems to be straightest and I'll carry a spare belt in case of another failure. It is called a 'fan spacer' rather than a 'pulley spacer' on mini spares, so I'm hoping this is the intention lol... Also there is a thicker 11mm one for 'clearing the timing cover', and if you tried to offset the pulley by 11mm it would be a disaster so i'm thinking they're generally for pushing the fan further inside the cowling.
This post has been edited by beentheunseen: Mar 8 2010, 08:51 PM
+Quote Post
mini danny
post Mar 8 2010, 08:51 PM
Post #10
Group: Members
Member of a Local Club?: british mini club
I couldn't quite get the belt quite straight with either arrangement... Just going to try it between the fan and pulley as that seems to be straightest and I'll carry a spare belt in case of another failure. It is called a 'fan spacer' rather than a 'pulley spacer' on mini spares, so I'm hoping this is the intention lol... Also there is a thicker 11mm one for 'clearing the timing cover', and if you tried to offset the pulley by 11mm it would be a disaster.
[/quote]
hiya mate this is off topic but are your seats still forsale thanks dan
+Quote Post
Paul Wiginton
post Mar 8 2010, 08:54 PM
Post #11
Group: Members
Member of a Local Club?: 'King Fast Mini Owners Club
The crank pulley is in the same place on all Minis so why would the waterpump pulley need to be spaced? It doesnt.
The spacer is just to push the fan blades clear of the timing cover breather, and the thicker ones are for Clubman as the radiator is further away.
Paul
+Quote Post
beentheunseen
post Mar 8 2010, 08:57 PM
Post #12
Group: Members
QUOTE
Nope sorry, they've been taken and are now marked as such - had too many messages to reply to everybody.
QUOTE
Paul
My thoughts exactly!
This post has been edited by beentheunseen: Mar 8 2010, 08:58 PM
+Quote Post
Sprocket
post Mar 8 2010, 10:28 PM
Post #13
Injection Mini Doc
Group: Mini Docs
Member of a Local Club?: Manchester Minis
QUOTE (R1minimagic @ Mar 8 2010, 07:45 PM) *
Both spacers should be between the pulley and the fan (IMG:style_emoticons/default/thumbsup.gif)
+Quote Post
post Mar 9 2010, 01:00 PM
Post #14
Group: Members
Member of a Local Club?: MCR, HAMOC, Chelmsford M.C.
Use the crank pulley as your basic datum for the fan belt centre-line.
Then check the alignment of the water pump pully. If necessary it can have a thin spacer behind it to get it in line, but this is almost never necessary. What is important is that it alignes accurately.
When those two are aligned, trial fit the alternator and use whatever washers you need to get the alternator pulley to align accurately. The spacer washers for the alternator must go on to the fitting bolt at the water pump lug. Then the other end of the alternator top bolt self-adjusts when tightened via the sliding sleeve. Make sure the bottom alternator clamp alignes without any pre-load, or the bracket can snap off in time.
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 6th September 2010 - 10:22 AM
MiniSpares banner
