hey guys,
i ahev a 1984 mayfair 998cc
what distance shoudl i adjust my spark plugs too as i have amisfire and im just doing this to see if it solves the problem.
imperial or metric dont mind got both measuring
cheers
dan
Spark Plug Distance
LESTA MINI
, Mar 08 2010 07:02 PM
7 replies to this topic
Posted 08 March 2010 - 07:02 PM
Posted 08 March 2010 - 07:17 PM
I was pretty sure it was 0.8mm but did a search to confirm and found conflicting answers.
Actually got mine set at 0.9 but Im running Lucas gold coil and electronic ignition which can stand a wider gap.
I'd go for 0.8 see how you get on.
My copy of Haynes only lists Champion, says for alternative makes check manufactorers guide lines.
1984 should be NGK BP6ES which NGK stae 0.8mm gap
Edited by lrostoke, 08 March 2010 - 07:20 PM.
Posted 08 March 2010 - 07:19 PM
25 thou??
Posted 08 March 2010 - 07:23 PM
Ignition system
Spark plugs:*
Type:
All models up to 1987 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Champion RN9YCC or RN9YC
998 cc engine models, 1987 to 1989 . . . . . . . . . . . . . . . . . . . . . . . Champion N12YCC or N12YC
998 cc engine models (1989-on) . . . . . . . . . . . . . . . . . . . . . . . . . . Champion RN12YCC or RN12YC
1275 cc engine models (1990-on) . . . . . . . . . . . . . . . . . . . . . . . . . Champion RN9YCC or RN9YC
Electrode gap:
All Champion plug types except RN9YC and N12YC . . . . . . . . . . 0.8 mm
Champion RN9YC and N12YC . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.6 mm
HT leads . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Champion LS-02, boxed set
*Spark plug types and electrode gaps are as recommended by Champion Spark Plug. If alternative plugs are used, refer to their manufacturer’s
recommendations.
Spark plugs:*
Type:
Electrode gap:
recommendations.
Posted 08 March 2010 - 08:06 PM
Use NGK BP6ES and gap to 25 thou
Posted 08 March 2010 - 08:07 PM
is that 25mm or 25 in imperial?
Posted 08 March 2010 - 08:21 PM
25 thousands of and inch. or 0.025 inches
Posted 08 March 2010 - 08:22 PM
cheers
