Welcome Guest ( Log In | Register )
> Don't give out incorrect advice - if you don't know the answer, don't post!
Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action.
Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
This is why we ask that only first-hand and factual information is posted in reply to peoples queries.
If you are not 100% certain of your reply, be sure to point out your uncertainty.
Reply to this topicStart new topic
> Overcooling Or Temp Sender/guage?
stickycreambun
post Mar 9 2010, 12:23 PM
Post #1
Group: TMF+ Member
1981 mini, MG Metro engine, 82deg thermostat (also tried 88deg, same result), 2-core rad, heater take off straight from head to matrix then back into bottom hose (manifold not plumbed in, no thermostat sandwich).
I start the engine and within a few minutes the temp starts to heat up. It gets to about half way between C and N and then stops (I presume when the thermostat opens). Even sat idling for 10-15 mins still wont raise it.
Is my engine running too cool?
I have a 2core rad that was already fitted with the previous 998, I know the thermostat is working, and the guage shoots to the H end when the sender is shorted out. But dunking the sender in boiling water still does not give a reading past halfway between C-N. I borrowed another temp sender to try, and exactly the same results.
(IMG:style_emoticons/default/oompf.gif)
Go to the top of the page
+Quote Post
post Mar 9 2010, 12:42 PM
Post #2
Group: Members
Member of a Local Club?: MCR, HAMOC, Chelmsford M.C.
It sounds OK, but with the poor accuracy of electrical temp gauges you never really know. The only way to be sure is to fit a capilliary-type gauge whih you can buy as a kit for c.£60. They are very accurate and easy to fit. Then you have a read out in deg. C.
This post has been edited by Cooperman: Mar 9 2010, 12:43 PM
+Quote Post
dklawson
post Mar 9 2010, 01:02 PM
Post #3
Tech Doc Admin
Group: Tech Admin
Member of a Local Club?: none
Before investing in anything else (t-stat, new gauge, etc) buy a modestly priced infrared thermometer. Bring the engine up to temperature and check the temperature of the top hose, radiator header tank, and t-stat housing. They will all read a bit different but should give you an idea of what's really going on. Once you know that you can make decisions about what else to buy.
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 31st July 2010 - 07:12 PM
MiniSpares banner
