Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action.
Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
This is why we ask that only first-hand and factual information is posted in reply to peoples queries.
If you are not 100% certain of your reply, be sure to point out your uncertainty.
Mar 9 2010, 04:28 PM
Post
Camshaft & Stage Two Head ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Joined: 3-January 10 From: middle of now where Member of a Local Club?: british mini club |
hiya
just started the mini and sounded like a bloody tractor think she only running on 3 cylinders not sure tho but when i put my foot down to about 4000 rpm i can hear the other cylinder tryinh to go it back fireing but only that 1 cylinder but when i put it to 6000rpm it back fired that stopped then it ran fine confused could it be it was a bit chilly or could be be its running rich or is any think else (IMG:style_emoticons/default/sad.gif) |
Mar 9 2010, 04:38 PM
Post
Up Into Fourth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Joined: 30-January 09 |
Maybe the engine is flooded. Try removing sparks and leave the petrol evaporate for about half hour. So you can have a look at spark plugs also, to check if mixture/timing are wrong...
Mar 9 2010, 04:41 PM
Post
Maybe the engine is flooded. Try removing sparks and leave the petrol evaporate for about half hour. So you can have a look at spark plugs also, to check if mixture/timing are wrong... she started and runs fine about from the 1 cylinder but it that cylinder kicked 1 once it reached 6000 rpm then i let the revs idle then i twas fine it judt didnt know if it was seriose or not ive just replaced spark plugs and it going rolling road next week becuase it running rich thanks dan |
Mar 9 2010, 04:47 PM
Post
Yes, its too rich and probably needs a different needle, so a RR session would be helpful.
But that issue could also be due to a stuck needle valve in float chamber. |
Mar 9 2010, 05:01 PM
Post
Mini Mad ![]() ![]() ![]() ![]() Group: TMF+ Member Joined: 3-May 07 From: Leicester Member of a Local Club?: Leicester Mini Club |
Lulu did this when one of the cells in the battery went. Sounded 100 times worse than a tractor, but it was running on all 4 and it got better at higher revs.
Mar 9 2010, 05:03 PM
Post
Lo-Fi Version | Time is now: 31st July 2010 - 07:16 PM |
