Welcome Guest ( Log In | Register )
> Don't give out incorrect advice - if you don't know the answer, don't post!
Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action.
Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
This is why we ask that only first-hand and factual information is posted in reply to peoples queries.
If you are not 100% certain of your reply, be sure to point out your uncertainty.
Reply to this topicStart new topic
> Electrics, wiring help
lee 1
post Mar 9 2010, 05:23 PM
Post #1
Starting My Mini Up
Group: Members
mayfair
1987
1275 cc
hi erveryone could someone shed some light on a problem with wiring i found on my newly purchased mini on drivers side inner wing found burnt out wiring !!! large brown wire from looking at it factory crimp splits in to three traced one to fuses one to inline fuse which left small brown wire only have about six inchs of cable this came out of crimp but cant trace where it went. loom is all checked right back in to dash so was thinking was this an aux wire left in the loom ? only found this as when driving along and switch side lights on it starts missing but not convinced this is causing problem just one ive found while looking any help would be great
Go to the top of the page
+Quote Post
post Mar 9 2010, 05:35 PM
Post #2
Group: Members
Member of a Local Club?: MCR, HAMOC, Chelmsford M.C.
You really need a ciruit diagram and a circuit tester to deal with electrics. It's hard to help with just a description to go on.
Get the Haynes Manual and trace each wire through. What I do when I have a wiring nightmare is to photocopy the Haynes then trace each wire through and mark it in red on the diagram. Then it becomes a logical and progressive job to sort it all out.
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 31st July 2010 - 07:12 PM
MiniSpares banner
