Welcome Guest ( Log In | Register )
> Don't give out incorrect advice - if you don't know the answer, don't post!
Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action.
Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
This is why we ask that only first-hand and factual information is posted in reply to peoples queries.
If you are not 100% certain of your reply, be sure to point out your uncertainty.
Reply to this topicStart new topic
> Speedo Going Crazy, How to fix irrattic speedo
Smith748
post Mar 9 2010, 05:51 PM
Post #1
Group: Members
Hi all,
I bought i mini end of last year (84 city 1000 E) it should of had twin clocks i think, but the guy had ripped them out and put a HOME MADE dash in with center smith clock.
I have just fitted the correct speedo cable and it works, but its random as to what speed i'm doing, in fact its not even close.
My question is how to fix it?
Do i need to get it calibrated or is it something to do with the voltage stabiliser?
Also to ad my fuel gauge doesn't work either.
Many thanks Mike
Go to the top of the page
+Quote Post
blacktulip
post Mar 9 2010, 06:08 PM
Post #2
Group: TMF+ Member
it wont be the voltage stabiliser as it is purely mechanical. is the cable screwed in all the way on the back and in the gearbox end? i had a similar experience and just swapped the speedo over and has been fine ever since.
+Quote Post
Smith748
post Mar 9 2010, 06:18 PM
Post #3
Group: Members
Hi i'll try that with changing the speedo, think the cable is right no movement.
+Quote Post
minicityE-2008
post Mar 9 2010, 07:08 PM
Post #4
Group: Members
QUOTE (Smith748 @ Mar 9 2010, 06:18 PM) *
Im sure there are a couple different speedo cable drives? Maybe it is the worng one you have? Also, i had a similar problem when i had the three dial cluster in mine and it was a problem where the cable wasnt properly attached to the back of the dial itself. so sometimes it would come free and the needle would drop to 0 and would suddenly catch again and go right up the dial then down again.
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 31st July 2010 - 07:21 PM
MiniSpares banner
