Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action.
Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
This is why we ask that only first-hand and factual information is posted in reply to peoples queries.
If you are not 100% certain of your reply, be sure to point out your uncertainty.
Mar 9 2010, 06:43 PM
Post
Speeding Along Now ![]() ![]() ![]() ![]() ![]() Group: TMF+ Member Joined: 2-August 08 From: Littlemoss, Ashton -U- Lyne Member of a Local Club?: None |
1991 City E 998
Std clutch master cylinder Asking for help again people. Second time in as many days, you can tell I'm putting things back together now ! I successfully rebuilt my brake master cylinder last night and now I'm onto the clutch. I have a new seal kit from Moss but seem to have a spare bit.....or have I?
Number of downloads: 6When I dismantled the unit, there was nothing that came close to the white plastic part I have in the kit. The only place I can see it fits is in the end of the spring
Number of downloads: 4Is this correct? Do I need it? No mention in the Haynes manual. Anyone have any experience or help. Thanks in advance Steve |
Mar 9 2010, 08:38 PM
Post
I appreciate its only a few hours since posting but I'm really keen to get this finished tonight if anyone can help.
Thanks Steve |
Mar 9 2010, 10:03 PM
Post
Mini Mad ![]() ![]() ![]() ![]() Group: TMF+ Member Joined: 24-January 10 |
If you're replacing the seals becuase they were leaking or just as part of maintenance on your mini, I'm sure you dont need it. If the cylinder worked ok before it should work ok without it again.
Mar 9 2010, 10:09 PM
Post
Thanks for the response.
I'm replacing the seals throughout the car as part of the rebuild not because I'm aware of any problem. A search took me to an American site where someone had asked the same question. It was suggested that the plastic part fits in a similar way to my second photo. As you have suggested, if it wasn't in there before, it probably won't be missed Thanks again. Steve |
Lo-Fi Version | Time is now: 31st July 2010 - 07:20 PM |
