Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action.
Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
This is why we ask that only first-hand and factual information is posted in reply to peoples queries.
If you are not 100% certain of your reply, be sure to point out your uncertainty.
Mar 9 2010, 07:00 PM
Post
Mini Mad ![]() ![]() ![]() ![]() Group: Members Joined: 17-December 09 |
Hiya guys,
Went for a burn in my mates mini today and after a while there was a squeeking sound from the front right wheel. Think its a bearing, but is there anything else that it could be? Thanks |
Mar 9 2010, 07:08 PM
Post
Doc and Trader ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Mini Docs Joined: 29-November 05 From: Midlands Member of a Local Club?: Central Minis |
Yep try checking your wheel nuts
Mar 9 2010, 07:10 PM
Post
Yeh ok i will do. What do you think could be happening with the wheel nuts being loose?
chears |
Mar 9 2010, 07:16 PM
Post
One Carb Or Two? ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Joined: 28-June 08 From: Boston Member of a Local Club?: Lincolnshire Mini Owners Club |
I would be suspecting wheel bearing, or possibly stuck brake pad with a constant squealing. Jack that wheel up and give it a shake while looking for movement. And also give it a spin to see if it feels / sounds smooth?
Ryan. |
Mar 9 2010, 08:25 PM
Post
I would have said brakes but squeeking can be a lot of things...
One of the most dangerous is probably a loose wheel, if it only happens whilst turning then suspect a ball joint.... but this would only really be squeeking if you had tightened one of them recently.... in my opinion it is dangerous to tighten ball joints that have seen use (IMG:style_emoticons/default/sad.gif) As above but look for loosness in any item of your suspension system (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 31st July 2010 - 07:14 PM |
