Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action.
Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
This is why we ask that only first-hand and factual information is posted in reply to peoples queries.
If you are not 100% certain of your reply, be sure to point out your uncertainty.
Mar 9 2010, 07:13 PM
Post
Mini Mad ![]() ![]() ![]() ![]() Group: TMF+ Member Joined: 17-August 09 From: Peterborough |
Hi
Don't know if anyone knows but i need to know what size of thread the hole for the adjuster screw on the rear drum backplate is.I know its UNF thread but its bigger than 9/16's.Anyone know what size it is as i need to tap the hole after it was powdercoated. Scott |
Mar 9 2010, 08:10 PM
Post
Camshaft & Stage Two Head ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: TMF+ Member Joined: 1-September 07 From: Buckinghamshire |
If you've got an old adjuster, clean it up, cut a couple of slots at an angle along the threads and use that to chase the thread,
JR |
Lo-Fi Version | Time is now: 31st July 2010 - 07:20 PM |
