Welcome Guest ( Log In | Register )
> Don't give out incorrect advice - if you don't know the answer, don't post!
Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action.
Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
This is why we ask that only first-hand and factual information is posted in reply to peoples queries.
If you are not 100% certain of your reply, be sure to point out your uncertainty.
Reply to this topicStart new topic
> Quick Spotlight Question
The-Womble
post Mar 9 2010, 08:38 PM
Post #1
Group: Members
Member of a Local Club?: Hexham Motor Club
Can someone please describe the difference between Driving Lamps, Fog Lamps and Spot Lamps.
I'm looking for a pair to get for my Mini for a road rally coming up soon...which would be best for that?
Thanks, Chris
Go to the top of the page
+Quote Post
mra-minis.co.uk
post Mar 9 2010, 09:04 PM
Post #2
Doc and Trader
Group: Mini Docs
Member of a Local Club?: Central Minis
Fog lights are an intense wide low pattern for cutting under the fog, hence low.
Spot lamps are long range lamps with a long narrow pattern for high speed driving (in a straight line)
Driving lamps are a cross, ie medium to long range and a little wider than the pattern created by spot lamps
Hope this helps (IMG:style_emoticons/default/smile.gif)
+Quote Post
The-Womble
post Mar 9 2010, 09:12 PM
Post #3
Group: Members
Ah right, cool. Thanks very much (IMG:style_emoticons/default/smile.gif)
+Quote Post
post Mar 10 2010, 12:40 PM
Post #4
Group: Members
Member of a Local Club?: MCR, HAMOC, Chelmsford M.C.
For a road-rally car, which is only allowed 2 extra lights, the best lights are the PIAA driving lights, although they are expensive. A good alternative is the Cibie Super-Oscar driving light. That's what I run on my 1964 Cooper 'S'.
Both will take 100 w bulbs, but you do need to have a good relay when wiring them in. Don't forget that the regulations require that they go out automatically when you dip the main beam, so the relay 'signal' feed must come from the main-beam circuit to a switch to the relay.
I hope this helps.
Spot or long-range lights are too much of a pencil-beam for rallying and fogs don't have any range, so always stick with driving lights.
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 31st July 2010 - 07:20 PM
MiniSpares banner
